Updated on 2025-10-10 GMT+08:00
Viewing the Container Node Protection Status
The Container Nodes page displays the protection, node, and agent status of containers, helping you learn the node security status in real time.
  • Only Linux servers are supported.
  • Servers that are not protected by HSS enterprise, premium, WTP, or container editions cannot perform container-related operations.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane, choose Asset Management > Containers. Click the Container Nodes tab.
  5. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  6. View the node protection status. For details, see Table 1.
    Table 1 Parameter description
    Server Information
    Server information, including the server name and IP address. You can hover your cursor over a server name to view the server details, including the server ID, OS, system name, and system version.
    Protection Status
    Protection status of a node. The options are as follows:
    • Unprotected: HSS is disabled for the server. After the agent is installed, click Enable in the Operation column to enable protection.
    • Enabled: The server is fully protected by HSS.
    • Protection interrupted: The server is shut down, the agent is offline, or the agent is uninstalled.
    Server Status
    • Running
    • Unavailable
    • Normal
    Agent Status
    You can select a status to view the server.
    • Online: The agent is running properly.
    • Offline: The communication between the agent and the HSS server is abnormal, and HSS cannot protect your servers.
    • Not installed: The agent has not been installed or successfully started.
