Updated on 2025-10-10 GMT+08:00
Server Alarms
HSS generates alarms on a range of intrusion events, including brute-force attacks, abnormal process behaviors, web shells, abnormal logins, and malicious processes. You can learn all these events on the console, and eliminate security risks in your assets in a timely manner.
Alarms generated by AV detection and HIPS detection are displayed under different types of events.
  • Alarms generated by AV detection are displayed only under the Malware events.
  • Alarms generated by HIPS detection are displayed in subcategories of all events.
Servers that are not protected by HSS do not support alarm-related operations.
Supported Alarms and Events
Event Type
Alarm Name
Basic Edition
Enterprise Edition
Premium Edition
WTP Edition
Add to Alarm Whitelist
Isolate and Kill
Malware
Unclassified malware
Malicious programs include Trojans and web shells implanted by hackers to steal your data or control your servers.
For example, hackers will probably use your servers as miners or DDoS zombies. This occupies a large number of CPU and network resources, affecting service stability.
Check malware, such as web shells, Trojan horses, mining software, worms, and other viruses and variants, and kill them in one-click. The malware is found and removed by analysis on program characteristics and behaviors, AI image fingerprint algorithms, and cloud scanning and killing.
Viruses
Detect viruses in server assets, report alarms, and support automatic or manual viruses isolation and killing based on the alarms.
Worms
Detect and kill worms on servers and report alarms.
Trojans
Detect and remove Trojan and viruses on servers and report alarms.
Botnets
Detect and kill botnets on servers and report alarms.
Backdoors
Detect backdoors in servers and reports alarms.
rootkits
Detect server assets and report alarms for suspicious kernel modules, files, and folders.
Ransomware
Check for ransomware in web pages, software, emails, and storage media.
Ransomware can encrypt and control your data assets, such as documents, emails, databases, source code, images, and compressed files, to leverage victim extortion.
√ (Partially supported)
Hacker tools
Detect and kill hacker tools on servers and reports alarms.
Web shells
Check whether the files (often PHP and JSP files) detected by HSS in your web directories are web shells.
You can configure the web shell detection rule in the Web Shell Detection rule on the Policies page. HSS will check for suspicious or remotely executed commands.
You need to add a protected directory in policy management. For details, see Web Shell Detection.
Isolation and removal: automated or manual
Mining
Detect, scan, and remove mining software on servers, and report alarms.
Vulnerability Exploits
Remote code execution
Detect and report alarms on server intrusions that exploit vulnerabilities in real time.
Abnormal System Behavior
Reverse shells
Monitor user process behaviors in real time to detect reverse shells caused by invalid connections.
Reverse shells can be detected for protocols including TCP, UDP, and ICMP.
You can configure the reverse shell detection rule in the Malicious File Detection rule on the Policies page. HSS will check for suspicious or remotely executed commands.
File privilege escalations
Detect file privilege escalation operations and generate alarms.
Process privilege escalations
Detect the privilege escalation operations of the following processes and generate alarms:
  • Root privilege escalation by exploiting SUID program vulnerabilities
  • Root privilege escalation by exploiting kernel vulnerabilities
Important file changes
Monitor important system files (such as ls, ps, login, and top) in real time and generate alarms if these files are modified. For details about the monitored paths, see Monitored Important File Paths.
HSS reports all the changes on important files, regardless of whether the changes are performed manually or by processes.
File/Directory changes
Monitor system files and directories in real time and generate alarms if such files are created, deleted, moved, or if their attributes or content are modified.
Abnormal process behaviors
Check the processes on servers, including their IDs, command lines, process paths, and behavior.
Send alarms on unauthorized process operations and intrusions.
The following abnormal process behavior can be detected:
  • Abnormal CPU usage
  • Processes accessing malicious IP addresses
  • Abnormal increase in concurrent process connections
x (Partially supported)
High-risk command executions
You can configure what commands will trigger alarms in the High-risk Command Scan rule on the Policies page.
HSS checks executed commands in real time and generates alarms if high-risk commands are detected.
Abnormal shells
Detect actions on abnormal shells, including moving, copying, and deleting shell files, and modifying the access permissions and hard links of the files.
You can configure the abnormal shell detection rule in the Malicious File Detection rule on the Policies page. HSS will check for suspicious or remotely executed commands.
Sensitive file access detection
Detect the unauthorized access to or modifications of sensitive files.
Suspicious crontab tasks
Check and list auto-started services, scheduled tasks, pre-loaded dynamic libraries, run registry keys, and startup folders.
You can get notified immediately when abnormal automatic auto-start items are detected and quickly locate Trojans.
System protection disabling
Detect the preparations for ransomware encryption, such as disabling the real-time protection of Windows defender through the registry. Once such an operation is detected, an alarm is reported immediately.
Backup deletion
Detect the preparations for ransomware encryption: Delete backup files or files in the Backup folder. Once backup deletion is detected, an alarm is reported immediately.
Suspicious registry operations
Detect operations such as disabling the system firewall through the registry and using the ransomware Stop to modify the registry and write specific strings in the registry. An alarm is reported immediately when such operations are detected.
System log deletions
An alarm is generated when a command or tool is used to clear system logs.
Suspicious command executions
  • Check whether a scheduled task or an automated startup task is created or deleted by running commands or tools.
  • Detect suspicious remote command execution.
Suspicious process execution
Detect and report alarms on unauthenticated or unauthorized application processes.
Suspicious process file access
Detect and report alarms on the unauthenticated or unauthorized application processes accessing specific directories.
Abnormal User Behavior
Brute-force attacks
If hackers log in to your servers through brute-force attacks, they can obtain the control permissions of the servers and perform malicious operations, such as steal user data; implant ransomware, miners, or Trojans; encrypt data; or use your servers as zombies to perform DDoS attacks.
Detect brute-force attacks on SSH, RDP, FTP, SQL Server, and MySQL accounts.
  • If the number of brute-force attacks (consecutive incorrect password attempts) from an IP address reaches 5 within 30 seconds, the IP address will be blocked. The default blocking duration is 12 hours.
  • You can check whether the IP address is trustworthy based on its attack type and how many times it has been blocked. You can manually unblock the IP addresses you trust.
Abnormal logins
Detect abnormal login behavior, such as remote login and brute-force attacks. If abnormal logins are reported, your servers may have been intruded by hackers.
  • Check and handle remote logins.
    You can check the blocked login IP addresses, and who used them to log in to which server at what time.
    If a user's login location is not any common login location, an alarm will be triggered.
  • Trigger an alarm if a user logs in to the server by a brute-force attack.
Invalid accounts
Hackers can probably crack unsafe accounts on your servers and control the servers.
HSS checks suspicious hidden accounts and cloned accounts and generates alarms on them.
User account added
Detect the commands used to create hidden accounts. Hidden accounts cannot be found in the user interaction interface or be queried by commands.
Password theft
Detect the abnormal obtaining of system accounts and password hashes on servers and report alarms.
Abnormal Network Access
Cloud honeypot
An alarm is reported if a connection to the honeypot port of a server is detected.
Abnormal outbound connection
Report alarms on suspicious IP addresses that initiate outbound connections.
Port forwarding
Report alarms on port forwarding performed using suspicious tools.
Suspicious download request
An alarm is generated when a suspicious HTTP request that uses system tools to download programs is detected.
Suspicious HTTP requests
An alarm is generated when a suspicious HTTP request that uses a system tool or process to execute a remote hosting script is detected.
Reconnaissance
Port scan
Detect scanning or sniffing on specified ports and report alarms.
Host scan
Detect the network scan activities based on server rules (including ICMP, ARP, and nbtscan) and report alarms.
Fileless Attacks
Process injection
Scan for malicious code injection into running processes and report alarms.
Dynamic library injection
Scan for the payloads injected by hijacking functions in the dynamic link library (DLL) and report alarms.
Memory file process
Scan for the behaviors of creating an anonymous malicious file that exists only in the RAM through the memfd_create system call and executing the file, and report alarms on such behaviors.
Security Alarm Severities
HSS alarm severities indicate alarm impact on service systems. It can be Critical, High, Medium, or Low. For details, see Table 1.
Table 1 Security alarm severities
Alarm Severity
Critical
A critical alarm indicates that the system is severely attacked, which may cause data loss, system breakdown, or long service interruption. For example, such alarms are generated if ransomware encryption behaviors or malicious programs are detected. You are advised to handle the alarms immediately to avoid severe system damage.
High
A high-risk alarm indicates that the system may be under an attack that has not caused serious damage. For example, such alarms are generated if unauthorized login attempts are detected or unsafe commands (for deleting critical system files or modifying system settings) are executed. You are advised to investigate and take measures in a timely manner to prevent attacks from spreading.
Medium
A medium-risk alarm indicates that the system has potential security threats, but there are no obvious signs of being attacked. For example, if abnormal modifications of a file or directory are detected, there may be potential attack paths or configuration errors in the system. You are advised to further analyze and take proper preventive measures to enhance system security.
Low
A low-risk alarm indicates that a minor security threat exists in the system but does not have significant impact on your system. For example, such alarms are generated if port scans are detected, indicating that there may be attackers trying to find system vulnerabilities. These alarms do not require immediate emergency measures. If you have high requirements on asset security, pay attention to the security alarms of this level.
Type
Linux
bin
/bin/ls
/bin/ps
/bin/bash
/bin/login
usr
/usr/bin/ls
/usr/bin/ps
/usr/bin/bash
/usr/bin/login
/usr/bin/passwd
/usr/bin/top
/usr/bin/killall
/usr/bin/ssh
/usr/bin/wget
/usr/bin/curl
