Access Process
This section describes how to connect servers and containers to HSS for protection when you use HSS for the first time.
HSS provides asset management, vulnerability detection, baseline check, intrusion detection, ransomware protection, and web tamper protection functions to comprehensively identify security risks in servers and containers, prevent intrusions, and help you build a secure server and container environment.
Access Process
Perform the following operations to connect a server or container to HSS.
No. |
Step |
Description |
1 |
The HSS agent is a piece of software installed on cloud servers to exchange data between the servers and HSS, implementing security check and protection for servers and containers. You can use HSS only after installing the agent. |
2 |
