Updated on 2025-10-10 GMT+08:00
How Do I Fix Vulnerabilities?
  1. Check the vulnerability detection results.
  2. Based on provided solutions, fix vulnerabilities one by one in descending order by severity.
    • Restart the Windows OS after you fix its vulnerabilities.
    • Restart the Linux OS after you fix its kernel vulnerabilities.
  3. HSS scans all Linux servers, Windows servers, and Web-CMS servers for vulnerabilities every early morning. After you fix the vulnerabilities, you are advised to perform a check immediately to verify the result.
