Updated on 2025-10-10 GMT+08:00
What Should I Do If WTP Cannot Be Enabled?
The causes of this problem vary by scenarios.
Agent Status Is Abnormal
  • Symptom
    The agent status is Offline or Not installed in the server list on the Web Tamper Protection page.
  • Solution
    Rectify the fault by following the instructions provided in How Do I Fix an Abnormal Agent. Ensure that Agent Status in the server list is Online.
Basic/Enterprise/Premium Edition HSS Has Been Enabled
  • Symptom
    Protection Status is Enabled in the server list on the HSS console.
  • Solution
    Disable HSS and then enable WTP.
    HSS editions include the basic, enterprise, premium, and WTP editions. Before enabling WTP for a server, ensure that basic, enterprise, or premium edition HSS has been disabled for the server.
Protection Was Enabled on the Wrong Page
To enable WTP, choose Web Tamper Protection > Servers.
