Help Center/
Host Security Service/
User Guide (Kuala Lumpur Region)/
FAQs/
Web Tamper Protection/
How Do I Modify a Protected Directory?
Updated on 2025-10-10 GMT+08:00
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation pane, choose Server Protection > Web Tamper Protection.
- Locate the target server and click Configure Protection in the Operation column.
- Click Settings. On the Protected Directory Settings page on the right, select the directory to be edited and click Edit in the Operation column.
- If you need to modify files in the protected directory, stop protection for the protected directory first.
- After the files are modified, resume protection for the directory in a timely manner.
- In the Edit Protected Directory dialog box, modify the settings and click OK.
Parent topic: Web Tamper Protection
