Help Center/ Host Security Service/ User Guide (Kuala Lumpur Region)/ FAQs/ Others/ How Do I Enable Logging for Login Failures?
Updated on 2025-10-10 GMT+08:00
MySQL
The account hacking prevention function for Linux supports MySQL 5.6 and 5.7. Perform the following steps to enable logging for login failure:
  1. Log in to the host as the root user.
  2. Run the following command to query the log_warnings value:
    show global variables like 'log_warnings'
  3. Run the following command to change the log_warnings value:
    set global log_warnings=2
  4. Modify the configuration file.
    • For a Linux OS, modify the my.conf file by adding log_warnings=2 to [MySQLd].
vsftp
This section shows you how to enable logging for vsftp login failures.
  1. Modify the configuration file (for example, /etc/vsftpd.conf) and set the following parameters:
    vsftpd_log_file=log/file/path
    dual_log_enable=YES
  2. Restart the vsftp service. If the setting is successful, log records shown in the logs shown in Figure 1 will be returned when you log in to vsftp.
    Figure 1 Log Records
