Updated on 2025-10-10 GMT+08:00
Checking the Dashboard
On the HSS dashboard, you can check the security score, risks, and protection overview of all your assets in real time, including servers and containers.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane, choose Overview.
  5. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  6. View asset security information. For details, see Overview.
    Table 1 Overview components
    Component
    Resource Overview
    Check the percentage of unprotected servers or containers, and agents to be upgraded.
    • Click the number of unprotected resources to go to the server or container management page and view the unprotected resource list.
    • Click the number of agents to be upgraded to go to the agent list and upgrade agents.
    HSS will be continuously upgraded to provide new features and fix bugs. To enjoy better HSS features, upgrade the agent to the latest version in a timely manner. For details, see Upgrading the agent.
    Secure score
    The security score is in the range 0 to 100. The default score for risk-free assets is 100. Points are deducted based on baseline risks, vulnerability risks, intrusion risks, and asset risks. A low score indicates high security risks in assets. To ensure the security of your assets, you are advised to handle security risks in a timely manner and improve the security score.
    1. In the Security Score area, click View Now.
    2. In the Handle Now dialog box, view the deduction items and click to expand the details.
    3. Click Handle on the right of deduction items to go to the corresponding risk list. You can rectify the fault based on the risk details and handling suggestions.
      For details about the score deduction items and how to increase the score, see Security Scores Criteria and Methods for Improving Scores.
    4. After the risk is fixed, click Scan to update the score.
    News
    Latest vulnerability information.
    Security risk
    Security risks detected by HSS in your assets.
    • Server Risks
      • Urgent/Total Alarms (Last 24 Hours): Number of alarms that need to be handled immediately and the total number of alarms.
        You can click the number of urgent alarms to go to the Alarms page and handle alarms. For details, see Handling Server Alarms.
      • Critical/Total Vulnerabilities: Number of critical vulnerabilities and the total number of vulnerabilities.
        You can click the number of critical vulnerabilities to go to the Vulnerabilities page and handle vulnerabilities. For details, see Handling Vulnerabilities.
      • Unsafe Settings: Number of baseline risks to be handled.
        You can click the number to go to the Baseline Checks page and fix baseline risks. For details, see Viewing and Processing Baseline Check Results.
      • Suspicious Processes to Be Handled: Total number of suspicious processes to be handled.
        You can click the number of suspicious processes to be handled to go to the Application Process Control page and handle suspicious processes. For details, see Checking and Handling Suspicious Processes.
    • Container Risks
      High-Priority/Total Vulnerabilities: Number of high-risk vulnerabilities and the total number of vulnerabilities.
      You can click the number of high-priority vulnerabilities to go to the Image Vulnerabilities tab and check vulnerability fixing suggestions. For details, see Viewing SWRImage Repository Vulnerabilities.
    • Risk Trend
      Asset risk trend in the last seven days.
    Protection overview
    Asset protection overview.
    • Assets: Total number of assets in the current region.
      You can click the total number of assets to go to the Assets page to view asset distribution and protection status.
    • Unprotected/Total Servers: Number of unprotected servers and the total number of servers.
      You can click the number of unprotected servers to go to the Servers page to view servers and enable protection. For details, see Enabling Protection.
    • Unprotected/Total Containers: Number of unprotected containers and the total number of containers.
      You can click the number of unprotected containers to go to the Containers page to view containers and enable protection. For details, see Enabling Protection.
    • Vulnerability update time: The latest update time of the vulnerability.
    • Security feature status: The number of servers protected by each feature and the number of items detected by each feature.
      You can click View Details to go to corresponding feature page.
    Related Services
    Security services related to HSS. Click a service name to go to its console.
The security score for risk-free assets is 100. A low score indicates high security risks in assets. HSS calculates your security score based on detected security items (vulnerabilities, compliance, intrusions, assets, and images) and unprotected assets. Scores are deducted every time a risk is detected in a category until all scores in that category are deducted. The full score of each category is as follows:
  • No vulnerabilities detected: 20. For details about the score deduction criteria and improvement methods, see Table 2.
  • No compliance risks detected: 20. For details about the score deduction criteria and improvement methods, see Table 3.
  • No intrusion risks detected: 30. For details about the score deduction criteria and improvement methods, see Table 4.
  • No asset risks detected: 10. For details about the score deduction criteria and improvement methods, see Table 5.
  • No image risks detected: 10. For details about the score deduction criteria and improvement methods, see Table 6.
  • No unprotected assets detected: 10. For details about the score deduction criteria and improvement methods, see Table 7.
Table 2 Vulnerability risks score deduction criteria and improvement methods
Category
Score Deduction Item
Affected HSS Edition
Points Deducted
Multiply Deducted Score by Risk Quantity
Unhandled vulnerabilities
Unhandled critical vulnerabilities
All
10
Fix vulnerabilities based on the suggestions provided, scan for vulnerabilities again, and update the score.
Unhandled high-risk vulnerabilities
All
3
Unhandled medium-risk vulnerabilities
All
Unhandled low-risk vulnerabilities
All
0.1
No vulnerability scan
No vulnerability scans were performed in the past month.
All
15
  • The basic edition HSS does not provide vulnerability scan. To use this feature, upgrade HSS to the enterprise or premium edition.
  • In HSS enterprise, premium, and WTP editions, you are advised to perform vulnerability scans. For details, see Scanning Vulnerabilities.
Table 3 Compliance risks score deduction criteria and improvement methods
Category
Points Deducted
Unhandled non-compliance items
Unhandled high-risk non-compliance items
All
10
Rectify non-compliance items, perform a baseline check again, and update the score.
Unhandled medium-risk non-compliance items
All
3
Unhandled low-risk non-compliance items
All
Weak passwords
Weak passwords
All
10
Use strong passwords.
Weak password check not enabled
Weak password check policy not enabled
All
10
Enable the Weak Password Detection policy to check for weak passwords on servers. For details, see Policy Management Overview.
Baseline check not performed
No baseline checks were performed in the past month.
All
10
  • The HSS basic edition does not provide baseline check. To use this feature, you are advised to upgrade HSS to the enterprise or premium edition.
  • In HSS professional, enterprise, premium, and WTP editions, you are advised to perform baseline checks. For details, see Viewing and Editing a Policy.
Table 4 Intrusion risks score deduction criteria and improvement methods
Category
Points Deducted
Unhandled alarms
Critical alarms not fixed
All
10
Handle alarms based on the suggestions provided. After alarms are handled, HSS will automatically update the score. For details, see Handling Server Alarms and Handling Container Alarms.
Unhandled high-risk alarms
All
3
Unhandled medium-risk alarms
All
Unhandled low-risk alarms
All
0.1
Protection not enabled
No security policies enabled
All
30
In the HSS enterprise, premium, WTP, and container editions, you need to enable protection policies. For details, see Policy Management Overview.
The intrusion detection policies that need to be enabled for each edition are as follows:
  • Enterprise edition
    • Linux: web shell detection, file protection, HIPS detection, login security check, malicious file detection, abnormal process behaviors, root privilege escalation, real-time process, and rootkit detection
    • Windows: AV detection, web shell detection, HIPS detection, login security check, and real-time process
  • Premium/WTP edition
    • Linux: cluster intrusion detection, web shell detection, file protection, HIPS detection, login security check, malicious file detection, port scan detection, abnormal process behaviors, root privilege escalation, real-time process, and rootkit detection
  • Container edition
    Cluster intrusion detection, container escape detection, web shell detection, container file monitoring, container process whitelist, and suspicious image behaviors
Login security policy not enabled
All
10
In HSS enterprise, premium, WTP, and container editions, you need to enable the Login Security Check policy for servers. For details, see Policy Management Overview.
Ransomware prevention policy not enabled
Premium edition
15
The HSS premium, WTP, and container editions support ransomware prevention. In these editions, you need to enable the ransomware prevention policy and the backup policy. (10 points will be deducted if backup is not enabled.) For details, see Enabling Ransomware Prevention.
WTP policy is not enabled
WTP edition
20
In the HSS WTP edition, you need to enable WTP policy for servers. For details, see Enabling Protection.
Container runtime detection policy not enabled
Container edition
20
In the HSS container edition, you need to enable container escape, container process whitelist, container file monitoring, and container information collection policies and apply them to servers. For details, see Overview.
Table 5 Asset risks score deduction criteria and improvement methods
Category
Points Deducted
Open ports
Open TCP/UDP high-risk ports
All
You are advised to disable unnecessary ports. To enable a port, choose Asset Management > Server Fingerprints, click Open Ports, and ignore the port.
Asset discovery not enabled
Asset discovery policy not enabled
All
5
  • The HSS and enterprise editions do not provide asset discovery. To use this feature, upgrade HSS to the premium edition.
  • In the HSS premium and WTP editions, you are advised to enable the Asset Discovery policy. For details, see Policy Management Overview.
Table 6 Image risks score deduction criteria and improvement methods
Category
Points Deducted
Unsafe images
High-risk images
Container edition
3
Re-create an image, scan the image, and update the score.
Medium-risk images
Container edition
Medium-risk images
Container edition
0.1
Image security scan not performed
No image security scans were performed in the past month.
Container edition
5
In the HSS container edition, you are advised to perform image security scans. For details, see:
Table 7 Unprotected assets risks score deduction criteria and improvement methods
Category
Points Deducted
Server protection not enabled
Unprotected servers
All
0.1–1
The points deducted for an unprotected server vary depending on its asset importance:
  • Important asset: 1
  • General asset: 0.5
  • Test asset: 0.1
You are advised to enable protection for your server as soon as possible. For details, see Enabling Protection.
