Managing the Login Whitelist
You can configure the IP addresses of destination servers, login IP addresses, login usernames, and user behaviors on the Login Whitelist tab page.
You can:
- Add the false alarms of the Brute-force attack and Abnormal login types to the whitelist. For details, see Viewing Server Alarms.
- Add whitelist items on the Login Whitelist tab page.
- If the destination server IP address, login IP address, and username of a login are all whitelisted, this login will be allowed without checking.
- After an IP address is added to a whitelist by following the instructions in Add an Item to the Login Whitelist, the alarms (if any) that have been generated for the IP address will not be automatically cleared. Handle the alarms by referring to Viewing Server Alarms.
- To unblock IP addresses, add the IP address to the whitelist of the login security detection policy. For details, see Login Security Check.
- Click
in the upper left corner and select a region or project. - In the upper left corner of the page, click
and choose . - Choose Detection & Response > Whitelists. Click Login Whitelist and click Add.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- On the displayed page, enter the server IP address, login IP address, and login username.
Table 1 Login Whitelist parameters Parameter
Example Value
Server IP Address
IP address or subnet mask of the destination server.
- IP address: for example, 192.168.1.1 or 16A0::1
- IP subnet mask: for example, 192.168.7.0/24 or 16A0:10:AB00:1E::/64
192.168.1.1
Login IP Address
Login Username
Current login username
hss_test
Remarks
Custom whitelist description
Test
Handle historical alarms
After this option is selected, login alarms that have been generated will be synchronized.
Selected
- Click OK.
Deleting an Item from the Login Whitelist
To delete an item from the Login Whitelist, select it and click Delete above the list, or click Delete in its Operation column.
