Updated on 2025-10-10 GMT+08:00
Viewing Server Protection Status
You are advised to periodically check the server protection status and handle security risks in a timely manner to prevent asset loss.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane on the left, choose Asset Management > Servers.
  5. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  6. In the server list, view the protection status of servers. For details, see Server protection status.
    You can check the server name, ID, IP address, OS, running status, and enterprise project. To set the items to be displayed in the server protection list, click in the upper right corner.
    • Searching for a server
      To check the protection status of a server, enter a server name, server ID, or IP address in the search box above the server protection list.
    • Viewing servers of a certain type
      On the left of the server protection list, select a server protection edition or an asset importance category to view the protection status of each type of servers.
    • Viewing server protection information
      The Protection Status column indicates whether a server is protected. The protection status of a server is determined by Agent Status and Server Status. You can view the server risk detection status in the Risk Level column. For details about the preceding parameters, see Table 1.
      Table 1 Protection description
      Server Status
      HSS can only protect running servers. If the server is in the Stopped or other state, you cannot perform security checks or fix risks on the server.
      Agent Status
      • Not installed: The agent has not been installed or successfully started.
        Click Install Agent and install the agent as prompted.
      • Online: The agent has been installed and running properly.
      • Offline: The agent has been installed, but the agent is disconnected from the HSS remote protection center. In this case, HSS cannot provide protection. For more information, see How Do I Fix an Abnormal Agent?
      • Installation failed: An error or problem occurred, leading to an installation failure. Click next to the installation failure status to view the cause. Rectify the fault by referring to What Should I Do If Agent Installation Failed?
      • Installing: The agent is being installed.
      Protection Status
      • Enabled: The server is fully protected by HSS.
      • Unprotected: HSS is disabled for the server. After the agent is installed, click Enable in the Operation column to enable protection.
      • Protection interrupted: The server is shut down, the agent is offline, or the agent is uninstalled.
      Risk Level
      Risk status of a server. (Data is updated every 24 hours.)
      • Risky: The server has risks. Hover your cursor over a risk icon to view risk distribution details. Click a risk quantity to go to the risk details page.
      • Safe: No risks are found.
      • Pending risk detection: HSS is not enabled for the server.
Viewing the WTP Status
  1. Choose Server Protection > Web Tamper Protection. The Servers tab page is displayed.
  2. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  3. Check the server protection status.
    Table 2 Statuses
    Dynamic WTP
    Status of dynamic WTP, which can be:
    • : Dynamic WTP is enabled.
    • : Dynamic WTP is disabled. (After enabling dynamic WTP, restart Tomcat to make this setting take effect.)
    Static Tampering Attacks
    Number of times that static web page files are attacked and tampered with.
    Dynamic Tampering Attacks
    Number of web application vulnerability exploits and injection attacks.
