Configuring Public Access
To access a RocketMQ instance over a public network, enable public access and configure EIPs for the instance. If you no longer need public access to the instance, disable it.
You can change the public access setting only when the RocketMQ instance is in the Running state.
Enabling Public Access
- Click
in the upper left corner to select a region.
Select the region where your RocketMQ instance is located.
- Click
and choose Application > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ. - Click a RocketMQ instance to go to the instance details page.
- Click
next to Public Access. - Click
, in the Elastic IP Address area, select the required number of IP addresses, and click
- Only IPv4 EIPs can be bound to RocketMQ instances.
- If no EIP exists in the Elastic IP Address drop-down list box, or the EIPs are insufficient, click Create Elastic IP to create an EIP on the page that is displayed. After the EIP is created, return to the RocketMQ console, click
next to Elastic IP Address, and select the new EIP from the drop-down list.
Figure 1 Enabling public access
After public access is enabled, Instance Address (Public Network) is displayed for instances. .
After public access is enabled, modify security group rules before attempting to access the RocketMQ instance.
Table 1 Security group rules Direction
Protocol
Port
Source
Inbound
TCP
8200
0.0.0.0/0
The port is used for public access to metadata nodes.
Inbound
TCP
10100-10199
0.0.0.0/0
The port is used for accessing service nodes.
Disabling Public Access
- Click
- Click
- Click
and then
to disable public access.
After public access is disabled, modify security group rules before attempting to access the RocketMQ instance over the private network.Table 2 Security group rules Direction
Protocol
Port
Source
Inbound
TCP
8100
0.0.0.0/0
The port is used for intra-VPC access to metadata nodes.
Inbound
TCP
10100-10199
0.0.0.0/0
