Help Center/
Distributed Message Service for RocketMQ/
User Guide (Kuala Lumpur Region)/
Managing Consumer Groups/
Deleting a Consumer Group
Updated on 2024-04-08 GMT+08:00
Delete consumer groups if they are no longer needed.
- Click
in the upper left corner to select a region.
Select the region where your RocketMQ instance is located.
- Click
and choose Application > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ. - Click a RocketMQ instance to go to the instance details page.
- In the navigation pane, choose Consumer Groups.
- Delete consumer groups using any of the following methods:
- In the row containing the consumer group you want to delete, click Delete.
- Click a consumer group to go to the consumer group details page and then click Delete in the upper right corner.
- To delete multiple consumer groups at a time, select the consumer groups, and click Delete Consumer Group above the consumer group list.
- Click OK.
Parent topic: Managing Consumer Groups
