Step 4: Connect to a RocketMQ Instance to Create and Retrieve Messages
This section describes how to use TCP to connect to a RocketMQ instance with SSL in CLI mode.
- A RocketMQ instance has been created following the instructions in Step 2: Create a RocketMQ Instance, and the instance addresses have been recorded.
- Security group rules have been configured.
- A topic has been created and you have obtained the topic name.
- An ECS has been created. For intra-VPC access, ensure that its VPC, subnet, and security group configurations are the same as those of the RocketMQ instance.
- You have installed the JDK and configured the environment variables. For details, see Step 1: Prepare the Environment.
Accessing the Instance with CLI
- Download the rocketmq-tutorial software package.
wget https://dms-demo.obs.cn-north-1.myhuaweicloud.com/rocketmq-tutorial.zip
- Decompress the rocketmq-tutorial package.
unzip rocketmq-tutorial.zip
- Go to the rocketmq-tutorial/bin directory.
cd rocketmq-tutorial/bin
- Create normal messages using the sample project.
JAVA_OPT=-Dtls.enable=true sh mqadmin sendMessage -n "${Connection addresses}" -t ${Topic name} -p "hello rocketmq"Parameter description:
- Connection addresses: the RocketMQ instance address.
- Topic name: name of the topic created for the RocketMQ instance
In the following example, 100.xxx.xxx.89:8200;100.xxx.xxx.144:8200 are the connection addresses to the RocketMQ instance, and topic-test is the topic name.
JAVA_OPT=-Dtls.enable=true sh mqadmin sendMessage -n "100.xxx.xxx.89:8200;100.xxx.xxx.144:8200" -t topic-test -p "hello rocketmq"
Press Ctrl+C to exit.
- Retrieve normal messages using the sample project.
JAVA_OPT=-Dtls.enable=true sh mqadmin consumeMessage -n "${Connection addresses}" -t ${Topic name}Parameter description:
JAVA_OPT=-Dtls.enable=true sh mqadmin consumeMessage -n "100.xxx.xxx.89:8200;100.xxx.xxx.144:8200" -t topic-test
To stop consuming messages, press Ctrl+C to exit.
- Create messages with traces using the sample project.
JAVA_OPT=-Dtls.enable=true sh mqadmin sendMessage -n "${Connection addresses}" -t ${Topic name} -p "hello rocketmq" -m trueParameter description:
JAVA_OPT=-Dtls.enable=true sh mqadmin sendMessage -n "100.xxx.xxx.89:8200;100.xxx.xxx.144:8200" -t topic-test -p "hello rocketmq" -m true
- Retrieve messages and send the message traces using the sample project.
JAVA_OPT=-Dtls.enable=true sh mqadmin consumeMessage -n "${Connection addresses}" -t ${Topic name} -m trueParameter description:
JAVA_OPT=-Dtls.enable=true sh mqadmin consumeMessage -n "100.xxx.xxx.89:8200;100.xxx.xxx.144:8200" -t topic-test -m true
