Help Center/
Graph Engine Service/
User Guide (Kuala Lumpur Region)/
Accessing and Analyzing Graph Data/
Adding Custom Operations
Updated on 2022-12-08 GMT+08:00
You can add custom operations executed by calling APIs. You can create shortcut operation sets.
- In the Operations tab on the left of the graph editor, click Edit . The Add Operation button is displayed.
- Click Add Operation and set the following parameters in the displayed dialog box:
- Name: Enter a name for the custom operation.
- API Type: cypher, gremlin, algorithm, and path_query are supported.
- Request Body: Enter the request body for the calling the API.
- Description: Add a description for the operation.
- Click OK. These parameters cannot be changed after the operation is added.
- The new custom operation is displayed in the Operations tab. You can click the run button to execute the operation and view the results on the canvas.
Parent topic: Accessing and Analyzing Graph Data
