- What's New
- Billing
- Getting Started
User Guide
- GES Overview
- Preparations
- Permissions Management
- Metadata Operations
- Creating Graphs
Managing Graphs
- Graph Management Overview
- Viewing a Failed Graph
- Backing Up and Restoring Graphs
- Upgrading a Graph
- Rolling Back a Graph
- Exporting a Graph
- Restarting a Graph
- Resizing a Graph
- Expanding a Graph
- Binding and Unbinding an EIP
- Clearing Data
- Deleting a Graph
- Viewing Monitoring Metrics
- Querying Schema
- Connecting GES to LTS
- Changing a Security Group
- Changing the Security Mode
- Data Migration
Accessing and Analyzing Graph Data
- Accessing an Infinite Graph
- Graph Editor
- Accessing the Graph Editor
- Dynamic Graphs
- Graph Exploration
- Multi-Graph Management (Database Edition)
- HyG Graph Management (Database Edition)
- Adding Custom Operations
- Editing Schema
- Hiding Sensitive Information About a Graph
- Visual Query
- Canvas Snapshot
- Gremlin Query
- Cypher Query
- DSL Query
- Analyzing Graphs Using Algorithms
- Managing Indexes
- Analyzing Graphs on the Canvas
- Graph Display in 3D View
- Filter Criteria
- Editing Properties
- Statistics Display
- Check Running Records
- Viewing Query Results
- Viewing Graph Tasks
- Configuring Permissions
- O&M Monitoring
- Package Management
- Algorithms
Developer Guide
- Overview
- Using the Management Plane SDK
Using the Service Plane SDK
- Downloading and Installing the SDK
- Obtaining Initialization Parameters
- Java SDK
- Python SDK
- Using Cypher JDBC Driver to Access GES
API Reference
- Before You Start
- API Overview
- Calling APIs
Management Plane APIs (V2)
- System Management
Graph Management
- Listing Graphs (2.1.18)
- Querying Graph Details (1.0.0)
- Creating a Graph (2.2.2)
- Stopping a Graph (1.0.0)
- Starting a Graph (1.0.0)
- Deleting a Graph (1.0.0)
- Incrementally Importing Data to a Graph (2.1.14)
- Exporting a Graph (1.0.5)
- Clearing a Graph(2.1.2)
- Upgrading a Graph (1.0.5)
- Binding an EIP (1.0.6)
- Unbinding an EIP(1.0.6)
- Changing Size (2.2.21)
- Forcibly Restarting a Graph (2.2.21)
- Expanding a Graph (2.2.23)
- Changing the Security Group (2.4.3)
- Backup Management
- Metadata Management
- Task Center
- Plugin Management
Service Plane APIs
Memory Edition
Vertex Operation APIs
- Querying Vertices That Meet Filter Criteria (1.0.0)
- Querying Vertex Details (1.0.0)
- Adding a Vertex (1.0.6)
- Deleting a Vertex (1.0.6)
- Updating Vertex Properties (1.1.6)
- Batch Querying Vertex Data (1.1.9)
- Batch Adding Vertices (2.1.16)
- Batch Deleting Vertices (2.1.9)
- Batch Updating Vertex Properties (2.1.10)
- Adding a Vertex Label (1.1.6)
- Deleting a Vertex Label (1.1.6)
- Exporting Filtered Vertices (2.2.7)
- Deleting Filtered Vertices (2.2.7)
Edge Operation APIs
- Querying Edges That Meet Filter Criteria (1.0.0)
- Querying Edge Details (1.0.0)
- Adding an Edge (2.1.2)
- Deleting an Edge (1.0.6)
- Updating Edge Properties (1.1.6)
- Batch Querying Edge Data (1.1.6)
- Batch Adding Edges (2.1.16)
- Batch Deleting Edges (2.1.9)
- Batch Updating Edge Properties (2.1.10)
- Exporting Filtered Edges (2.2.7)
- Deleting Filtered Edges (2.2.7)
- Metadata Operation APIs
- Index Operation APIs
- Gremlin Operation APIs
Algorithm APIs
- Running Algorithms (1.0.0)
Algorithm API Parameter References
- Common Algorithm Parameters
- PageRank (1.0.0)
- PersonalRank (1.0.0)
- K-core (1.0.0)
- K-hop (1.0.0)
- Common Neighbors (1.0.0)
- Common Neighbors of Vertex Sets (2.2.13)
- Link Prediction (1.0.0)
- Shortest Path (2.1.5)
- All Shortest Paths (1.0.12)
- Filtered Shortest Path (2.2.4)
- SSSP (1.0.0)
- Shortest Path of Vertex Sets (2.1.5)
- n-Paths (1.1.2)
- Filtered n-Paths (2.2.22)
- Filtered All Pairs Shortest Paths (2.2.17)
- All Shortest Paths of Vertex Sets (2.2.15)
- Filtered All Shortest Paths (2.2.17)
- Connected Component (1.0.0)
- Label Propagation (2.1.8)
- Louvain (2.2.1)
- Node2vec (1.0.5)
- Real-time Recommendation (2.2.21)
- Degree Correlation (1.0.0)
- Triangle Count (1.0.0)
- Cluster Coefficient (1.0.0)
- Closeness Centrality (1.0.0)
- Betweenness Centrality (2.2.4)
- Edge Betweenness Centrality (2.2.4)
- Origin-Destination Betweenness Centrality (2.2.4)
- Circle Detection with a Single Vertex (2.2.4)
- Filtered Circle Detection (2.2.15)
- Subgraph Matching (2.2.16)
- Topicrank (2.2.20)
- Temporal Graph APIs
- Path APIs
- Graph Statistics APIs
- Graph Operation APIs
- Subgraph Operation APIs
- Job Management APIs
- Custom Operations APIs
- Cypher Queries (2.2.16)
- Filtered Query (2.2.13)
- Filtered Query V2 (2.3.6)
- Domain-Specific Language (DSL) Query APIs (2.3.14)
- Updating Specified Properties of Vertices and Edges by Importing a File (2.2.13)
- Deleting Vertices and Edges by Files (2.2.15)
- O&M Monitoring APIs
Database Edition
- Specification Description
- Vertex Operation APIs
- Edge Operation APIs
- HyG Graph Management APIs
HyG Algorithm APIs
- PageRank
- PersonalRank
- K-core
- K-Hop
- Shortest Path
- All Pairs Shortest Paths
- SSSP
- Triangle Count
- TopicRank
- Louvain
- Bigclam
- Cesna
- Infomap
- Label Propagation
- Subgraph Matching
- Link Prediction
- n Paths
- Maximum Common Connected Induced Subgraph (MCCIS)
- Algorithm Results in TXT Format
- Executing the DSL Algorithm
- DSL Syntax
- HyG Job Management APIs
- Native Algorithm APIs
- Cypher Operation APIs
- Interactive Transaction APIs
Memory Edition
- Application Examples
- GES Metrics on Cloud Eye
Out-of-Date APIs
Management Plane APIs (V1)
- System Management APIs
- Querying the Graph List (2.1.18)
- Incrementally Importing Data to Graphs (2.1.14)
- Resizing a Graph (2.2.21)
- Backup Management APIs
- Metadata Management APIs
- Task Center APIs
- Service Plane APIs
- Appendix
- Customer Consultation
API Use
- How Do I Import Data to GES?
- When Binding an EIP to an Existing Instance or an Instance Being Created, What Should I Do to Deal with Insufficient Permissions for Creating Agencies?
- When Binding an EIP to an Existing Instance or an Instance Being Created, What Should I Do to Deal with Insufficient Quotas for Creating Agencies?
- Can I Run Several Gremlin/Cypher Commands At a Time?
- If a Vertex Is Deleted, What Will Happen to Edges Formed Based on the Vertex?
- What Do I Do If an Error Message Indicating a Vertex Does Not Exist Is Displayed When Properties of the Vertex Whose ID Contains Chinese Characters Are Modified?
- GUI
- Others
More Documents
- GES Overview
- Creating Graphs
- Managing Graphs
- Graph Editor
- Accessing the GES Graph Editor
- Dynamic Graphs
- Graph Exploration
- Editing Schema
- Visual Query
- Gremlin Query
- Cypher Query
- DSL Query
- Filter Criteria
- View Running Records
- O&M Monitoring and Alarm Reporting
Algorithms
- Algorithm List
- PageRank
- PersonalRank
- K-core
- K-hop
- Shortest Path
- SSSP
- n-Paths
- Label Propagation
- Louvain
- Link Prediction
- Node2vec
- Common Neighbors
- Triangle Count
- Clustering Coefficient
- Subgraph Matching
- TopicRank
- Filtered n-Paths
- Temporal Paths
- Before You Start
- API Overview
- Calling APIs
- Management Plane APIs (V2)
Service Plane APIs
Memory Edition
- Querying Vertices Based on Filter Criteria
- Adding a Vertex
- Deleting a Vertex
- Updating a Vertex Property
- Querying Vertices in Batches
- Adding Vertices in Batches
- Deleting Vertices in Batches
- Updating Vertex Properties in Batches
Algorithm APIs
- Executing an Algorithm
- PageRank
- PersonalRank
- K-core
- K-Hop
- Common Neighbors
- Link Prediction
- Shortest Path
- SSSP
- n-Paths
- Filtered n-Paths
- Label Propagation
- Louvain
- Node2vec
- Triangle Count
- Subgraph Matching
- Topicrank
- Path APIs
- Filtered-query API
- Filtered-query V2
- Deleting Vertices and Edges by Reading Files
- Granular Permission Control APIs
Database Edition
- HyG Algorithm APIs
Memory Edition
- Monitoring Metrics
- Out-of-Date APIs
- Appendix
- GES Overview
- Importing Metadata
- Creating Graphs
- Managing Graphs
- Graph Editor
- Exploring Graphs
- Editing Schema
- Gremlin Query
- Cypher Query
- Filtering Conditions
Algorithms
- Algorithm List
- PageRank
- PersonalRank
- K-core
- K-hop
- Shortest Path
- SSSP
- n-Paths
- Label Propagation
- Louvain
- Link Prediction
- Node2vec
- Common Neighbors
- Triangle Count
- Subgraph Matching
- TopicRank
- Filtered n-Paths
- Before You Start
- Calling APIs
Service Plane APIs
- Adding a Vertex
- Deleting a Vertex
- Querying Vertex Data in Batches
- Adding a Label
- Updating a Label
- Query Labels (for 100-billion-edge graphs only)
- Querying Graph Metadata Details
- Changing Property Names in Batches
- Deleting a Label
- Adding Labels in Batches
- Adding Properties (for 100-billion-edge graphs only)
- Query Properties (for 100-billion-edge graphs only)
- Querying the Property List (for 100-billion-edge graphs only)
- Querying Schema Structure
- Generating a Schema Structure
Algorithm APIs
- PageRank
- PersonalRank
- K-core
- K-hop
- Shortest Path
- SSSP
- n-Paths
- Label Propagation
- Louvain
- Link Prediction
- Node2vec
- Common Neighbors
- Triangle Count
- Path APIs
- Querying K Hop Vertices or Edges Using a Filter
- Performing Cypher Queries
- GES Metrics
- Appendix
Filtered n-Paths
Overview
The filtered n-Paths algorithm is used to find no more than n k-hop loop-free paths between the source and target vertices. The start vertex (source), end vertex (target), number of hops (k), number of paths (n), and filter criteria (filters) are the parameters for the algorithm.
Application Scenarios
Any network
Parameter Description
Name |
Mandatory |
Description |
Object Type |
Value Range |
Default |
source |
Yes |
Source vertex |
String |
Internal vertices |
None |
target |
Yes |
Target vertex |
String |
Internal vertices |
None |
k |
Yes |
Number of hops |
Int |
[2,6] |
2 |
n |
Yes |
Number of paths |
Int |
[1,1000] |
1 |
