Updated on 2022-12-08 GMT+08:00
Filtered All Shortest Paths
Overview
The Filtered All Shortest Paths algorithm allows you to search query results of the Shortest Path algorithm for the paths that meet the conditions between two vertices in a graph.
Application Scenarios
This algorithm applies to scenarios such as relationship mining, path planing, and network planning.
Parameter Description
Table 1 Parameters
Name
Mandatory
Type
Value Range
Default
source
Yes
Source vertex ID
String
target
Yes
Target vertex ID
String
directed
No
Whether the edges are directed
Bool
The value can be true or false.
false
Example
Configure the parameters as follows: directed=true, source="Alice", target="Jay", and set the search condition to labelName=friends. The results are returned in JSON format.
