Subgraph Matching
Overview
The subgraph matching algorithm is used to find all subgraphs of a given small graph that is isomorphic to a given large graph. This is a basic graph query operation and is intended to explore important substructures of a graph.
Application Scenarios
This algorithm is applicable to fields such as social network analysis, bioinformatics, transportation, crowd discovery, and anomaly detection.
Parameter Description
Name |
Mandatory |
Description |
Type |
Value Range |
edges |
Yes |
Edge set of the subgraph to be matched. The vertex ID must be a non-negative integer. |
String |
The value is in standard CSV format. The start and end vertices of an edge are separated by a comma (,), and edges are separated by a newline character (\n). For example, 1,2\n2,3. |
vertices |
Yes |
Label of each vertex on the subgraph to be matched. |
String |
The value is in standard CSV format. Vertices and their labels are separated by commas (,), and labels are separated by newline characters (\n). For example, 1,BP\n2,FBP\n3,CP. |
directed |
No |
Whether the graph is directed |
Bool |
The value can be true or false. The default value is true. |
n |
No |
Maximum number of subgraphs to be searched for |
Int |
The value range is [1,100000]. The default value is 100. |
batch_number |
No |
Number of queries processed in batches each time |
Int |
The value range is [1,1000000]. The default value is 10000. |
statistics |
No |
Whether to display the number of all subgraphs that meet the conditions |
Bool |
The value can be true or false. The default value is false. |
