Cypher Query
Cypher is a declarative graph query language. You can use Cypher statements to obtain query result and modify data in GES.
- Access the GES graph editor. For details, see Accessing the GES Graph Editor.
 - Use label-based vertex and edge indexes during Cypher query.
 - In the graph data query area, enter the query statement and press Enter.
Cypher Statements
The following are typical query statements.
- Querying a vertex
match (n:movie) return n: Query the vertex whose label is movie.
match (n) return n limit 100: Query details about 100 vertices.
match (n{Occupation:'artist'}) return id(n), n.Gender limit 100: Query the first 100 vertices whose Occupation is artist, and return their IDs and genders.
match (n) where id(n)='Vivian' return n: Query the vertex whose ID is Vivian.
match (n) return n skip 50 limit 100: Query all vertices of a graph. Skip the first 50 vertices, and return a total of 100 vertices.
 - Querying an edge
match (n)-[r]->(m) return r, n, m: Query all edges. Return the edges and vertices at both ends.
match (n)-[r:rate]->(m) return r, n, m: Query the edges whose label is rate.
match (n)-[r:rate|:friends]-(m) where id(n)='Vivian' return n,r,m: Query all edges whose start vertex is Vivian and edge label is rate or friends.
 - Searching by path
match p=(n:user)--(m1:user)--(m2:movie) return p limit 100: Query the paths whose start vertex is user, first-hop end vertex is user, and second-hop end vertex is movie. Returns the first 100 paths.
 - Aggregating and deduplicating based on groups
match (n) return count(*): Query the number of all vertices in a graph.
match (n:user) return n.Gender, count(n): Collect statistics on the number of user vertices in every gender.
match (n:user) return distinct n.Occupation: Return deduplicated occupations of all user vertices.
 - Sorting
match (n:user) return id(n) as name order by name: Change IDs of all user vertices to name, and sort the vertices by name.
 - Creating a vertex
create(n:movie{_ID_:'The Captain', Year:2019})return n: Create a vertex whose ID is The Captain, label is movie, and Year is 2019. Return the vertex.
create(n:movie{_ID_:'The Captain', Year:2019})-[r:rate]-> (m:movie{_ID_:'The Climbers',Title: 'The Climbers', Year:2019}) return r: Create two vertices and their associated edges.
 - Creating an edge
match (n),(m) where id(n)= 'The Captain' and id(m)= 'Lethal Weapon' create (n)-[r:rate]->(m) return r : Create an edge whose label is rate between two vertices with specified IDs. (You are advised to use this query in 2.2.21 and later versions.)
 - Modifying properties
match (n) where id(n)= 'The Captain' set n.Title= 'The Captain' return n: Search for the vertex whose ID is The Captain and change the attribute Title to Ji Zhang.
 - Deleting a vertex
match (n) where id(n)=' The Captain' delete n: Search and delete the vertex whose ID is The Captain.
match (n) where id(n)=' "detach delete n": Search for the vertex whose ID is The Captain. Delete the vertex and its edges.
 - Querying a schema
If you call db.schema() independently, only the schema metadata of the vertices is returned. Multiple isolated vertices are displayed on the canvas.
   - You can press the up and down arrow keys in the text box to view historical query commands.
 - When you enter a syntax keyword, the system automatically displays historical statements with the same keyword.
      Figure 2 Historical queries
       - Keywords in the text box are displayed in different colors.
- Reserved words in gray
Note: A reserved word is predefined in the syntax system of a programming language. Reserved words vary depending on programming languages.
 - String values in orange
 - Key-value pairs in purple. They are of the non-string type in the key:value format.
 - Delimiters in red. Regular delimiters including square brackets [], curly brackets {}, parenthesis (), commas (,), and semicolons (;).
 - Variables in green
Figure 3 Cypher keywords
