Help Center/
Graph Engine Service/
User Guide (Kuala Lumpur Region)/
Managing Graphs/
Resizing a Graph
Updated on 2022-12-08 GMT+08:00
Resizing a Graph
If the storage capacity, computing capability, or service capability of a graph cannot meet service requirements, you can resize the graph.
- Currently, 10,000-edge and 10-billion-edge graphs cannot be resized.
- After the graph is resized, you need to re-create all indexes.
- In the navigation pane on the left, choose Graph Management. On the displayed page, locate the target graph and choose More > Resize in the Operation column.
- In the displayed dialog box, select the target specifications. You can only select higher specifications. For example, a graph with 1 million edges can be changed to 10 million, 100 million, 1 billion, or 10 billion edges.
- Click OK. The graph status changes to Preparing for resize. After several minutes, the graph status changes to Resizing. When the resize is complete, the graph status changes to Running.
Parent topic: Managing Graphs
