Role Permissions
Roles can be used for fairly coarse-grained permissions control. They grant service-level permissions based on user responsibilities. GES does not support custom roles. The following system roles are available.
       Role Name  |
       Description  |
       Tenant Guest  |
       Regular tenant users
       GES Administrator  |
       GES administrator
       GES Manager  |
       GES manager
       GES Operator  |
       Regular GES users
        If you have both the GES Operator and Tenant Guest permissions, you can view and access GES resources. If you do not have the Tenant Guest permissions, you cannot view resources or access graphs. To interact with OBS, for instance, to view the metadata, you need the OBS permissions. For details, see Common GES operations supported by each OBS policy.  |
       Operation  |
       GES Administrator  |
       GES Manager  |
       GES Operator  |
       Tenant Guest  |
       Creating graphs  |
       Yes  |
       No  |
       No  |
       No  |
       Deleting graphs  |
       Yes  |
       No  |
       No  |
       No  |
       Querying graphs  |
       Yes  |
       Yes  |
       Yes  |
       Yes  |
       Accessing graphs  |
       Yes  |
       Yes  |
       Yes  |
       No  |
       Importing data  |
       Yes  |
       Yes  |
       No  |
       No  |
       Creating metadata  |
       Yes  |
       Yes  |
       No  |
       No  |
       Viewing metadata  |
       Yes  |
       Yes  |
       Yes  |
       Yes  |
       Copying metadata  |
       Yes  |
       Yes  |
       No  |
       No  |
       Editing metadata  |
       Yes  |
       Yes  |
       No  |
       No  |
       Deleting metadata  |
       Yes  |
       Yes  |
       No  |
       No  |
       Clearing data  |
       Yes  |
       Yes  |
       No  |
       No  |
       Backing up graphs  |
       Yes  |
       Yes  |
       No  |
       No  |
       Restoring graphs from backups  |
       Yes  |
       Yes  |
       No  |
       No  |
       Deleting backups  |
       Yes  |
       Yes  |
       No  |
       No  |
       Querying backups  |
       Yes  |
       Yes  |
       Yes  |
       Yes  |
       Starting graphs  |
       Yes  |
       Yes  |
       No  |
       No  |
       Stopping graphs  |
       Yes  |
       Yes  |
       No  |
       No  |
       Upgrading graphs  |
       Yes  |
       Yes  |
       No  |
       No  |
       Exporting graphs  |
       Yes  |
       Yes  |
       No  |
       No  |
       Binding EIPs  |
       Yes  |
       Yes  |
       No  |
       No  |
       Unbinding an EIP  |
       Yes  |
       Yes  |
       No  |
       No  |
       Viewing results in the task center  |
       Yes  |
       Yes  |
       Yes  |
       Yes  |
       Resizing a Graph  |
       No  |
       No  |
       Expanding a Graph  |
       No  |
       No  |
       Restarting a Graph  |
       Yes  |
       No  |
       GES Operation  |
       Dependent OBS Permission  |
       Viewing metadata  |
       OBS Viewer policy or OBS Buckets Viewer role  |
       Creating/Importing/Copying/Editing/Deleting metadata  |
       OBS Operator policy or Tenant Administrator role  |
       Creating, importing, and exporting graphs  |
