Clearing Data
If unnecessary data is imported or the imported data volume exceeds the graph size, you can clear the data.
In addition, if you delete data by mistake using Gremlin or Cypher commands, you can clear the broken data and import the correct data again.
This operation will clear all vertex and edge data of the graph. Exercise caution when performing this operation.
- Log in to the GES management console.
- In the navigation tree on the left, select Graph Management.
- Locate the target graph in the graph list and choose More > Clear Data in the Operation column.
- In the dialog box that is displayed, select or deselect Clear the metadata in the graph.
Deleted metadata cannot be recovered. Exercise caution when performing this operation.
- Click Yes.
