Shortest Path of Vertex Sets
Overview
The Shortest Path of Vertex Sets algorithm finds the shortest path between two vertex sets.
Application Scenarios
This algorithm applies to block relationship analysis in Internet social networking, financial risk control, road network transportation, and logistics delivery scenarios.
Parameter Description
Parameter |
Mandatory |
Description |
Type |
Value Range |
Default Value |
sources |
Yes |
Source vertex ID set |
String |
The value is in the standard CSV format. IDs are separated by commas (,), for example, Alice, Nana. The maximum ID number is 100,000. |
targets |
Yes |
Target vertex ID set |
String |
directed |
No |
Whether to consider the edge direction |
Bool |
true or false |
false |
timeWindow |
No |
Time window used for time filtering |
Json |
For details, see Table 2. |
Parameter |
Mandatory |
Description |
Type |
Value Range |
Default Value |
filterName |
No |
Name of the time attribute used for time filtering |
String |
Character string: The attribute on the corresponding vertex/edge is used as the time. |
filterType |
No |
Filtering by vertex or edge |
String |
V: Filtering by vertex E: Filtering by edge BOTH: Filtering by vertex and edge |
BOTH |
startTime |
No |
Start time |
String |
Date character string or timestamp |
endTime |
No |
End time |
String |
If a vertex ID contains commas (,), add double quotation marks to it. For example, when Paris, je taime and Alice IDs are used as sources, the ID set is "Paris, je taime",Alice".
Example
Set parameters directed to true, sources to "Alice,Nana", and targets to "Lily,Amy". The JSON result is displayed in the query result area.
