Updated on 2022-08-08 GMT+08:00
n-Paths
Overview
The n-Paths algorithm is used to find the n paths between two nodes within the layers of relationships in a graph.
Application Scenarios
This algorithm applies to scenarios such as relationship analysis, path design, and network planning.
Parameter Description
Table 1 n-Paths algorithm parameters
Mandatory
Type
Value Range
Default Value
source
Yes
Enter the source ID of a path.
String
target
Yes
Enter the target ID of a path.
String
directed
No
Whether to consider the edge direction
Bool
true or false
false
n
No
Number of paths
Int
1-100
10
k
No
Number of hops
Int
1-10
5
Example
Set parameters source to Lee, target to Alice, n to 10, k to 5, and directed to false. The calculation result is displayed on the canvas and the JSON result is displayed in the query result area.
