Updated on 2022-08-08 GMT+08:00
SSSP
Overview
The SSSP algorithm finds the shortest paths from a specified node (source node) to all other nodes.
Application Scenarios
This algorithm applies to scenarios such as path design and network planning.
Parameter Description
Table 1 SSSP algorithm parameters
Mandatory
Type
Value Range
Default Value
source
Yes
Node ID
String
directed
No
Whether to consider the edge direction
Bool
true or false
true
Example
Calculate the shortest paths from the Lee node to other nodes.
Set parameters source to Lee and directed to true.
