Updated on 2022-08-08 GMT+08:00
Louvain
Overview
Louvain is a modularity-based community detection algorithm with high efficiency and effect. It detects hierarchical community structures and aims to maximize the modularity of the entire community network.
Application Scenarios
This algorithm applies to scenarios such as community mining and hierarchical clustering.
Parameter Description
Table 1 Louvain algorithm parameters
Mandatory
Type
Value Range
Default Value
convergence
No
Convergence
Double
A real number between 0 and 1 (excluding 0 and 1)
0.00001
max_iterations
No
Maximum iterations
Int
1-2,000
100
weight
No
Weight of an edge
String
Empty or null character string
  • Empty: The default weight and distance are 1.
  • Character string: The attribute of the corresponding edge is the weight. When the edge does not have corresponding attribute, the weight is 1 by default.
The weight of an edge must be greater than 0.
weight
Precautions
This algorithm generates only the final community result and does not save the hierarchical results.
Example
Set parameters coverage to 0.00001 and max_iterations to 100, the sub-graphs of different communities are displayed on the canvas. The color of a node varies with communities. The JSON result is displayed in the query result area.
