Updated on 2022-08-08 GMT+08:00
Connected Component
Overview
A connected component stands for a sub-graph, in which all nodes are connected with each other. Path directions are involved in the strongly connected components and are not considered in the weakly connected components. This algorithm generates weakly connected components.
Parameter Description
None
Example
Run the algorithm to calculate the connected component to which each node belongs. The JSON result is displayed in the query result area.
