K-hop
Overview
K-hop is an algorithm used to search all nodes in the k layer that are associated with the source node through breadth-first search (BFS). The found sub-graph is the source node's ego-net. The K-hop algorithm returns the number of nodes in the ego-net.
Application Scenarios
This algorithm applies to scenarios such as relationship discovery, influence prediction, and friend recommendation.
Parameter Description
Parameter |
Mandatory |
Description |
Type |
Value Range |
Default Value |
k |
Yes |
Number of hops |
Integer |
1-100 |
source |
Yes |
Node ID |
String |
mode |
No |
Direction:
String |
OUT, IN, ALL |
OUT |
Precautions
- A larger k value indicates a wider node coverage area.
- According to the six degrees of separation theory, all people in social networks will be covered after six hops.
- BFS searches information based on edges.
Example
Calculate the sub-graph formed by the three hops starting from the Lee node.
Set parameters k to 3, source to Lee, and mode to OUT. The sub-graph is displayed on the canvas, and the JSON result is displayed in the query result area.
