Restoring a Graph
If the graph data being edited is incorrect, you can load the backup data to restore the graph data for analysis.
Ten-thousand-edge graphs cannot be automatically backed up. You need to back up a graph and restore data from the manul backup. For graphs of other sizes, you can restore data from an automatic backup or manual backup.
- Log in to the GES management console.
- In the navigation tree on the left, select Backup Management.
- On the Backup Management page, locate the target backup and click Restore in the Operation column.
- In the Restore dialog box, select This operation will overwrite the target graph. After the restoration starts, the graph will be restarted using the backup. Click Yes.
- After a message is prompted indicating that the restoration is successful, you can access the target graph and obtain the restored data on the Graph Management page.
