Help Center/
Graph Engine Service/
User Guide (Kuala Lumpur Region)/
Managing Graphs/
Deleting a Graph
Updated on 2022-12-08 GMT+08:00
Deleting a Graph
If you have analyzed the graph data, you can delete the graph to release resources.
Backups of a graph will be also deleted after the graph is deleted, and data cannot be recovered. Exercise caution when performing this operation.
- Log in to the GES management console.
- In the navigation tree on the left, select Graph Management.
- Locate the target graph in the graph list and choose More > Delete in the Operation column.
- In the displayed dialog box, select Release the EIP bound with the graph instance. This option is available only for graphs have EIPs bound.Select Keep one auto backup and two manual backups, which occupy the quota as required.
- Click Yes to complete the deletion.
Parent topic: Managing Graphs
