Help Center/
Graph Engine Service/
User Guide (Kuala Lumpur Region)/
Creating Graphs/
Stopping a Graph
Updated on 2022-12-08 GMT+08:00
Stopping a Graph
If you do not need to use a graph, you can stop it. After the graph is stopped, you cannot access it.
Resources are not released after you stop the graph.
- Log in to the GES management console.
- In the navigation tree on the left, select Graph Management.
- Locate the target graph in the graph list and choose More > Stop in the Operation column.
- The graph status changes to Stopping. Wait several minutes. When the graph is successfully stopped, the graph status is switched to Stopped.
Parent topic: Creating Graphs
