On this page
Adding a CNAME Record Set
Updated on 2022-08-16 GMT+08:00
If you want to map one domain name to another, add a CNAME record set for the domain name.
For more details, see Record Set Types and Configuration Rules.
  • You can leave the Name parameter blank when adding a CNAME record set.
  • You cannot create a CNAME record set with the same name and resolution line as an NS record set.
  2. In the service list, choose Network > Domain Name Service.
    The DNS console is displayed.
  1. In the navigation pane, choose Private Zones.
    The zone list is displayed.
  2. Click in the upper left corner and select the desired region and project.
  3. Click the zone name.
  4. Click Add Record Set.
    The Add Record Set dialog box is displayed.
  1. Set required parameters based on Table 1.
    Table 1 Parameters for adding a CNAME record set
    Example Value
    Name
    Prefix of the domain name to be resolved.
    For example, if the zone name is example.com, the domain name prefix can be as follows:
    • www: The domain name is www.example.com, which is usually used for a website.
    • Left blank: The domain name is example.com.
      In some cases, you may need to set the record set name to the at sign (@). However, the at sign is not supported. Leave the Name blank.
    • abc: The domain name is abc.example.com, a subdomain of example.com.
    • mail: The domain name is mail.example.com, which is typically used for an email server.
    • *: The domain name is *.example.com, which is a wildcard domain name, indicating all subdomains of example.com.
    Left blank
    Type
    Type of the record set
    If a message is displayed indicating that the record set you are trying to create exists, the record set conflicts with an existing record set.
    CNAME – Map one domain to another
    TTL (s)
    Cache duration of the record set on a local DNS server, in seconds.
    The value ranges from 300 to 2147483647, and the default is 300.
    If your service address changes frequently, set TTL to a smaller value.
    The default value is 300s, which is, 5 minutes.
    Value
    Domain name alias. You can enter only one domain name.
    webserver01.example.com
    Tag
    (Optional) Identifier of the record set.
    Each tag contains a key and a value. You can add a maximum of 10 tags to a record set. This parameter is displayed when you expand More Settings.
    For details about tag key and value requirements, see Table 2.
    example_key1
    example_value1
    (Optional) Supplementary information about the record set.
    You can enter a maximum of 255 characters.
    Table 2 Tag key and value requirements
    Requirements
    Example Value
    Key
    • Cannot be left blank.
    • Must be unique for each resource.
    • Can contain a maximum of 36 characters.
    • Cannot start or end with a space or contain special characters =*<>\,|/
    example_key1
    Value
    • Can contain a maximum of 43 characters.
    example_value1
  2. Click OK.
  3. Switch back to the Record Sets page.
    View the added record set in the record set list of the zone and ensure that the status of the record set is Normal.
