Disassociating a VPC from a Private Zone
Disassociate a VPC from a private zone if you do not want the private domain name to be resolved in this VPC. If a private zone has only one VPC associated, you cannot disassociate the VPC.
![](https://support.huaweicloud.com/intl/en-us/my-kualalumpur-1-usermanual-dns/public_sys-resources/note_3.0-en-us.png)
If you do not intend to use private domain names, delete the private zone configured for it.
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane, choose Private Zones.
The Private Zones page is displayed.
- Click
in the upper left corner and select the desired region and project.
- Locate the private zone from which a VPC is to be disassociated, select the VPC to be disassociated under Associated VPC, and click
on the right of the VPC.
- In the Disassociate VPC dialog box, click Yes.
