Updated on 2025-10-29 GMT+08:00
Overview
Tags can be used to identify SSL certificates. You can use tags to group certificates by usage, owner, or environment and manage them centrally.
You can add a tag when purchasing a certificate or add a tag on the certificate details page after the purchase.
Tag Naming Rules
  • Each tag consists of a key-value pair.
  • A maximum of 20 tags can be added for an SSL certificate.
  • For each certificate, a tag key must be unique and can have only one tag value.
  • A tag consists of a tag key and a tag value. The naming rules are listed in Table 1.
    Table 1 Tag parameters
    Rule
    Example
    Tag key
    • This parameter is mandatory.
    • An SSL certificate can have only one tag key.
    • The value can contain a maximum of 128 characters.
    • The value cannot start or end with a space.
    • The value cannot start with _sys_.
    • The following character types are allowed:
      • Chinese
      • English
      • Digit
      • Space
      • Special characters: _.:=+-@
    cost
    Tag value
    • This tag value can be left blank.
    • The value can contain a maximum of 255 characters.
      • Chinese
      • English
      • Digit
      • Space
    100
