Configuring a CRL
If you want to publish the certificate revocation list (CRL) for a private CA, you can enable CRL configuration.
This topic walks you through how to enable or disable CRL configuration.
The private CA for which you want to configure a CRL is in the Activated or Disabled state.
Enabling CRL Configuration
- Click
in the upper left corner of the page and choose . The service console is displayed. - Click the name of a private CA. The private CA details page is displayed.
- On the private CA details page, click the CRL Configuration tab and configure certificate revocation. Configure certificate revocation parameters by referring to Certificate revocation parameters.
Table 1 Certificate revocation parameters Parameter
OBS Authorization
Whether to authorize CCM to access your OBS bucket and upload the CRL file.
If you want to authorize, click Authorize Now and complete the authorization as prompted.
If you want to cancel the authorization, go to the IAM console to delete the PCAAccessPrivateOBS agency from the agency list.
After the permission has been granted, follow-up operations do not require the permission to be granted again.
Enable CRL publishing
Indicates whether to enable CRL publishing.
OBS Bucket
Select an existing OBS bucket or click Create OBS Bucket to create an OBS bucket.
CRL Update Period
Indicates the CRL update period. PCA will generate a new CRL at the specified time.
You can set the period to an integer between 7 and 30. If you do not specify a value, it is set to 7 days by default.
- Click Enable to enable the CRL. If the system displays a message indicating that the CRL configuration is enabled, the CRL configuration has been enabled.
Disabling CRL Configuration
- Click
- On the private CA details page, click the CRL Configuration tab and click Disable. If the system displays a message indicating that the CRL configuration is disabled, the CRL configuration has been disabled.
