Personal Data Protection
To ensure that your personal data, such as the username, password, and mobile phone number, will not be obtained by unauthorized or unauthenticated entities or people and to prevent data leakage, CCM encrypts your personal data before storing it to control access to the data and records logs for operations performed on the data.
Personal Data
Table 1 lists the personal data generated or collected by CCM.
        Type  |
        Collection Method  |
        Can Be Modified  |
        Mandatory  |
        Tenant ID  |
        No  |
        Yes. The tenant ID is the certificate resource ID.  |
        Email Address  |
        Email address entered when applying for the private certificate  |
        No  |
        No  |
CCM uses encryption algorithms to encrypt your sensitive data and stores encrypted data.
- Tenant IDs: Tenant IDs are not sensitive data and are stored in plaintext.
 - email address: encrypted for storage
Access Control
Token authentication is required for accessing your personal data in the CCM database.
Logging
CCM logs all operations involving personal data, such as editing, querying, and deleting personal data. The logs are uploaded to Cloud Trace Service (CTS). You can view only the logs for your operations.
