Viewing Details of a Private Certificate
This topic describes how to view details of a private certificate, including the common name, expiration time, and status.
You have applied for a private certificate. For details, see Applying for a Private Certificate.
 - Click
 in the upper left corner of the page and choose . The service console is displayed. In the navigation pane on the left, choose . - View the private certificate information. Table 1 describes the private certificate parameters.
Table 1 Private certificate parameters Parameter
Common Name
Indicates the name of the private certificate configured during certificate application.
Issued By
Indicates the name of the private CA that issues the private certificate.
Creation Time
Indicates the time when a private certificate is created.
Expiration Time
Indicates the time when a certificate expires.
Status
Indicates the certificate status. The value can be:
- Issued
The private certificate is issued.
 - Expired
The private certificate is expired.
 - Revoked
The private certificate is revoked.
Enterprise Project
Enterprise project to which the private certificate belongs.
Operation
You can download, revoke, or delete the certificate.
 - Issued
 - Click the common name of a private certificate to view its details.
You can click Add Tag on the tab page of the private certificate details page to identify the private certificate. TMS's predefined tag function is recommended for adding the same tag to different cloud resources.
