Help Center/
Cloud Container Engine/
User Guide (Kuala Lumpur Region)/
FAQs/
Networking/
Security Hardening/
How Do I Prevent Cluster Nodes from Being Exposed to Public Networks?
Question
How do I prevent cluster nodes from being exposed to public networks?
Solution
- If access to port 22 of a cluster node is not required, you can define a security group rule that disables access to port 22.
- Do not bind an EIP to a cluster node unless necessary.
Parent topic: Security Hardening
