Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ FAQs/ Storage/ Can I Create a CCE Node Without Adding a Data Disk to the Node?
  • Data disks are required.
    A data disk dedicated for kubelet and the container engine will be attached to a new node. By default, CCE uses LVM to manage data disks. With LVM, you can adjust the disk space ratio for different resources on a data disk.
    If the data disk is uninstalled or damaged, the container engine will malfunction and the node becomes unavailable.
