On this page
EOM of CentOS
Released: Oct 23, 2024
CentOS has reached its end of maintenance (EOM) date, which means it will no longer receive updates or support. The CentOS public images on CCE are sourced from the official CentOS. As a result, CCE will no longer provide support for CentOS once it is no longer maintained. This section describes the effects of the CentOS EOM and offers solutions to mitigate them.
Background
On December 8, 2020, CentOS officially announced the plan to stop maintaining CentOS Linux and launched CentOS Stream. For more information, see the CentOS official documentation.
CentOS 8 ended on December 31, 2021, and CentOS 7 ended on June 30, 2024. CentOS 9 and any future versions are no longer available, and there will be no further software patches or updates provided by the CentOS official. CentOS services may be exposed to risks or even become unavailable, and it will not be possible to restore them in a timely manner.
Impact
According to the official CentOS change plan, there will be the following impacts on users:
  • CentOS 7 users cannot receive any software maintenance or support, including bug fixes and feature updates, after June 30, 2024.
  • CCE will not remove CentOS 7 public images, and nodes created with CentOS 7 will not be affected, but images will no longer get updated.
  • CCE will provide support for CentOS in line with the official CentOS release date.
Solution
  • For a newly created node pool or node
    When creating a node pool or node, change CentOS to a supported OS.
  • For an existing node pool
    Change CentOS to a supported OS. If you do not need to modify the node configurations, such as the number and type of VPCs and disks, but you want to modify the node OS image and your software is not tightly linked to the original OS, it is recommended that you reset the node to change the OS.
    1. In the navigation pane, choose Nodes. On the displayed page, click the Node Pools tab.
    2. Select the node pool to be updated, click Update, and change CentOS to a supported OS.
    3. In the node list of the target node pool, select a node and choose More > Reset Node in the Operation column. (After a node is reset, the node OS will be reinstalled. Before resetting a node, drain the node to gracefully evict the pods running on the node to other available nodes. Perform this operation during off-peak hours.)
    Supported OS
    Intended Audience
    Ubuntu
    Ubuntu is a Linux distribution. Different OSs reflect different usage habits and application compatibilities.
    Individuals or enterprises who can handle the cost of switching OSs
    NOTICE:
    To upgrade a node's OS, replace the system disks in batches. It is important to avoid storing any important data in the system disks or back up the data beforehand. The upgrade process will not affect the data disks.
