Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ Best Practices/ Container/ Locating Container Faults Using the Core Dump File
Updated on 2025-12-08 GMT+08:00
Application Scenarios
A core dump is when the Linux OS saves the memory status to a file after a program crashes or stops unexpectedly. You can analyze the file to locate the fault.
Generally, when a service application crashes, its container exits and is reclaimed and destroyed. Therefore, container core files need to be permanently stored on the host or cloud storage. This topic describes how to configure container core dumps.
Notes and Constraints
When a container core dump is persistently stored to OBS (parallel file system or object bucket), the default mount option umask=0 is used. As a result, although the core dump file is generated, the core dump information cannot be written to the core file.
Enabling Core Dump on a Node
Log in to the node, run the following command to enable core dump, and set the path and format for storing core files:
echo "/tmp/cores/core.%h.%e.%p.%t" > /proc/sys/kernel/core_pattern
%h, %e, %p, and %t are placeholders, which are described as follows:
  • %h: hostname (or pod name). You are advised to configure this parameter.
  • %e: program file name. You are advised to configure this parameter.
  • %p: (Optional) process ID
  • %t: (Optional) time of the core dump
After the core dump function is enabled by running the preceding command, the generated core file is named in the format of core.{Host name}.{Program file name}.{Process ID}.{Time}.
You can also configure a pre-installation or post-installation script to automatically run this command when creating a node.
Permanently Storing Core Dumps
A core file can be stored in your host (using a hostPath volume) or cloud storage (using a PVC). The following is an example YAML file for using a hostPath volume.
apiVersion: v1
kind: Pod
  volumes:
  - name: coredump-path
    hostPath:
      path: /home/coredump
  containers:
  - name: ubuntu
    image: ubuntu:12.04
    command: ["/bin/sleep","3600"]
    volumeMounts:
    - mountPath: /tmp/cores
Create a pod:
kubectl create -f pod.yaml
Verification
  1. Obtain the pod name:
    kubectl get pod
    Information similar to the following is displayed:
    NAME        READY   STATUS    RESTARTS   AGE
    coredump    1/1     Running   0          56s
  2. Access the container:
    kubectl exec -it coredump -- /bin/sh
    After accessing the container, run the following command to trigger a segmentation fault of the current shell terminal:
    kill -s SIGSEGV $$
    command terminated with exit code 139
  3. Log in to the node and check whether the core file has been generated in /home/coredump.
    ls /home/coredump
    If information similar to the following is displayed, the core file has been generated.
    core.coredump.bash.18.1650438992
