Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ Best Practices/ Security/ Configuration Suggestions on CCE Secret Security
Currently, CCE has configured static encryption for secret resources. The secrets created by users will be encrypted and stored in etcd of the CCE cluster. Secrets can be used in two modes: environment variable and file mounting. No matter which mode is used, CCE still transfers the configured data to users. Therefore, it is recommended that:
  1. Do not record sensitive information in logs.
  2. For the secret that uses the file mounting mode, the default file permission mapped in the container is 0644. Configure stricter permissions for the file. For example:
    apiversion: v1
    kind: Pod
      containers:
      - name: mypod
        image: redis
        volumeMounts:
        - name: foo
          mountPath: "/etc/foo"
      volumes:
      - name: foo
        secret:
          secretName: mysecret
          defaultMode: 256
    In defaultMode: 256, 256 is a decimal number, which corresponds to the octal number 0400.
  3. When the file mounting mode is used, configure the secret file name to hide the file in the container.
    apiVersion: v1
    kind: Secret
    data:
      .secret-file: dmFsdWUtMg0KDQo=
    apiVersion: v1
    kind: Pod
      volumes:
      - name: secret-volume
        secret:
          secretName: dotfile-secret
      containers:
      - name: dotfile-test-container
        image: k8s.gcr.io/busybox
        command:
        - ls
        - "-1"
        - "/etc/secret-volume"
        volumeMounts:
          readOnly: true
          mountPath: "/etc/secret-volume"
    In this way, .secret-file cannot be seen by running ls -l in the /etc/secret-volume/ directory, but can be viewed by running ls -al.
  4. Encrypt sensitive information before creating a secret and decrypt the information when using it.
Using a Bound ServiceAccount Token to Access a Cluster
The secret-based ServiceAccount token does not support expiration time or auto update. In addition, after the mounting pod is deleted, the token is still stored in the secret. Token leakage may incur security risks. A bound ServiceAccount token is recommended for CCE clusters of version 1.23 or later. In this mode, the expiration time can be set and is the same as the pod lifecycle, reducing token leakage risks. An example is as follows:
apiVersion: apps/v1
kind: Deployment
  namespace: security-example
  replicas: 1
  selector:
    matchLabels:
      app: security-token-example
      label: security-token-example
  template:
      annotations:
        seccomp.security.alpha.kubernetes.io/pod: runtime/default
      labels:
      serviceAccountName: test-sa
      containers:
        - image: ...
          imagePullPolicy: Always
      volumes:
        - name: test-projected
          projected:
            defaultMode: 420
            sources:
              - serviceAccountToken:
                  expirationSeconds: 1800
                  path: token
              - configMap:
                  items:
                    - key: ca.crt
                      path: ca.crt
              - downwardAPI:
                  items:
                    - fieldRef:
                        apiVersion: v1
                        fieldPath: metadata.namespace
                      path: namespace
For details, see Managing Service Accounts.
Using the CCE Secrets Manager for DEW Add-on
The CCE Secrets Manager for DEW add-on (dew-provider) is used to interconnect with DEW. This add-on allows you to mount secrets stored outside a cluster (DEW for storing sensitive information) to pods. In this way, sensitive information can be decoupled from the cluster environment, which prevents information leakage caused by program hardcoding or plaintext configuration.
