Modifying Kernel Parameters Using a Privileged Container
To access a Kubernetes cluster from a client, you can use the Kubernetes command line tool kubectl.
- Create a DaemonSet on the backend, select the Nginx image, enable the privileged container, configure the lifecycle, and specify hostNetwork: true.
- Create a DaemonSet file.
vi daemonset.yaml
An example YAML file is provided as follows:
The spec.spec.containers.lifecycle field indicates the command that will be run after the container is started.
kind: DaemonSet apiVersion: apps/v1 metadata: name: daemonset-test labels: name: daemonset-test spec: selector: matchLabels: name: daemonset-test template: metadata: labels: name: daemonset-test spec: hostNetwork: true containers: - name: daemonset-test image: nginx:alpine-perl command: - "/bin/sh" args: - "-c" - while :; do time=$(date);done imagePullPolicy: IfNotPresent lifecycle: postStart: exec: command: - sysctl - "-w" - net.ipv4.tcp_tw_reuse=1 securityContext: privileged: true imagePullSecrets: - name: default-secret
- Create the DaemonSet.
kubectl create –f daemonSet.yaml
- Check whether the DaemonSet has been created.
kubectl get daemonset {daemonset_name}
In this example, run the following command:
kubectl get daemonset daemonset-test
Information similar to the following is displayed:
NAME DESIRED CURRENT READY UP-T0-DATE AVAILABLE NODE SELECTOR AGE daemonset-test 2 2 2 2 2 <node> 2h
- Obtain the IDs of the DaemonSet pods on the nodes.
kubectl get pod | grep {daemonset_name}
kubectl get pod | grep daemonset-test
daemonset-test-mqdpv 1/1 Running 0 2h daemonset-test-n56vm 1/1 Running 0 2h
- Access the container.
kubectl exec -it {pod_name} -- /bin/sh
kubectl exec -it daemonset-test-mqdpv -- /bin/sh
- Check whether the configured command is executed after the container is started.
sysctl -a |grep net.ipv4.tcp_tw_reuse
If the following information is displayed, the system parameters are modified successfully:
