Configuring a Custom EIP for a LoadBalancer Ingress
You can customize the EIP bound to a load balancer that is automatically created by CCE by adding the kubernetes.io/elb.custom-eip-id annotation to an ingress.
  • A CCE standard cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.18-r0 or later
    • v1.25: v1.25.13-r0 or later
    • v1.27: v1.27.10-r0 or later
    • v1.28: v1.28.8-r0 or later
    • v1.29: v1.29.4-r0 or later
    • v1.30: v1.30.1-r0 or later
    • Other clusters of later versions
  • The cluster can be accessed using kubectl. For details, see Connecting to a Cluster Using kubectl.
Notes and Constraints
  • A custom EIP for an ingress can be configured only when an ingress is being updated, and the ingress' annotation contains kubernetes.io/elb.eip-id.
  • A custom EIP must be unbound to any resources.
  • After you configure a custom EIP for a load balancer, if the existing EIP bound to the load balancer was automatically created by CCE during load balancer creation and is not being used by any other resources, the existing EIP will be deleted automatically when the associated ingress is deleted. However, if the existing EIP was manually created, it will be unbound from the load balancer when you delete the ingress, and you will need to manually delete the EIP.
Using kubectl
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Automatically create a load balancer with an EIP bound when creating an ingress. For details, see Automatically Creating a Load Balancer While Creating an Ingress.
    An example YAML file of an ingress created using a shared load balancer is as follows:
    kind: Ingress
      annotations:
        kubernetes.io/elb.autocreate: '{"type":"public","bandwidth_name":"test-eip
    ","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_g-vm","name":"test-eip"}'
        kubernetes.io/elb.class: union
        kubernetes.io/elb.eip-id: 10183660-0bb7-47d4-a899-18891b1ab2f7     # ID of the EIP automatically assigned during load balancer creation
        kubernetes.io/elb.id: aed5d5c9-65eb-42ab-9f80-57825cbae309
        kubernetes.io/elb.ip: 1.1.1.1
        kubernetes.io/elb.port: "80"
      namespace: default
      ingressClassName: cce
      rules:
      - http:
          paths:
          - backend:
              service:
                port:
                  number: 80
            path: /
            property:
    status:
      loadBalancer:
        ingress:
        - ip: 192.168.1.138
  3. Modify the ingress configurations and add the kubernetes.io/elb.custom-eip-id annotation.
    kind: Ingress
      annotations:
        kubernetes.io/elb.custom-eip-id: 57bf8bb2-8c7d-4d07-8799-aae16a421802  # ID of the custom EIP
      namespace: default
      rules:
      - http:
          paths:
          - backend:
              service:
                port:
                  number: 80
            path: /
            property:
    status:
      loadBalancer:
        ingress:
        - ip: 192.168.1.138
    Table 1 Key parameters
    Type
    String
    ID of the custom EIP, which can be seen on the EIP console
    The EIP must be bindable.
  4. After the ingress is updated, check the ingress again.
    kind: Ingress
      annotations:
        kubernetes.io/elb.custom-eip-status: '{"id":"57bf8bb2-8c7d-4d07-8799-aae16a421802","public_ip_address":"3.3.3.3"}' # After the custom EIP is configured, record the EIP's ID and IP address.
      namespace: default
      rules:
      - http:
          paths:
          - backend:
              service:
                port:
                  number: 80
            path: /
            property:
    status:
      loadBalancer:
        ingress:
        - ip: 192.168.1.138
