Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ Network/ Service/ LoadBalancer/ Changing a Custom EIP for a LoadBalancer Service
Updated on 2025-07-07 GMT+08:00
You can customize the EIP bound to a load balancer that is automatically created by CCE by adding the kubernetes.io/elb.custom-eip-id annotation to a Service.
  • A Kubernetes cluster is available and the cluster version meets the following requirements:
    • v1.23: v1.23.18-r0 or later
    • v1.25: v1.25.13-r0 or later
    • v1.27: v1.27.10-r0 or later
    • v1.28: v1.28.8-r0 or later
    • v1.29: v1.29.4-r0 or later
    • v1.30: v1.30.1-r0 or later
  • The cluster can be accessed using kubectl. For details, see Accessing a Cluster Using kubectl.
Notes and Constraints
  • A custom EIP for a Service can be configured only when the Service is being updated, and the Service's annotation contains kubernetes.io/elb.eip-id.
  • A custom EIP must be unbound to any resources.
  • After you configure a custom EIP for a load balancer, if the existing EIP bound to the load balancer was automatically created by CCE during load balancer creation and is not being used by any other resources, the existing EIP will be deleted automatically when the associated Service is deleted. However, if the existing EIP was manually created, it will be unbound from the load balancer when you delete the Service, and you will need to manually delete the EIP.
Using kubectl
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Automatically create a load balancer with an EIP bound when creating a Service. For details, see Using kubectl to Create a Service (Automatically Creating a Load Balancer).
    An example YAML file of a Service created using a dedicated load balancer is as follows:
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.autocreate: '{"type":"public","bandwidth_name":"aaaaa","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_g-vm","name":"xxx","available_zone":["xxx"],"elb_virsubnet_ids":["fc0c61cd-c987-49c4-99a4-b7d816b57581"],"l7_flavor_name":"","l4_flavor_name":"L4_flavor.elb.pro.max","vip_subnet_cidr_id":"cf35b03f-c6ca-4f75-aa70-e2166cb1f800"}'
        kubernetes.io/elb.eip-id: 8560972c-2cc5-4699-94d6-e46f146eb73d     # ID of the EIP automatically assigned during load balancer creation
        kubernetes.io/elb.class: performance
        kubernetes.io/elb.id: 0e78a84a-7deb-4747-aeb6-09b6a820b001
      labels:
        app: test-svc
        version: v1
      namespace: default
      allocateLoadBalancerNodePorts: true
      clusterIP: 10.247.93.235
      clusterIPs:
      - 10.247.93.235
      externalTrafficPolicy: Cluster
      internalTrafficPolicy: Cluster
      ipFamilies:
      - IPv4
      ipFamilyPolicy: SingleStack
      loadBalancerIP: *.*.*.*
      ports:
      - name: cce-service-0
        nodePort: 31354
        port: 80
        protocol: TCP
        targetPort: 80
      selector:
        app: test-svc
        version: v1
      sessionAffinity: None
      type: LoadBalancer
    status:
      loadBalancer:
        ingress:
        - ip: *.*.*.*
        - ip: 192.168.0.15
  3. Modify the Service configurations and add the kubernetes.io/elb.custom-eip-id annotation.
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.custom-eip-id: 88c197a1-cb85-4b38-b672-1d60dc5d00db  # ID of the custom EIP
      labels:
        app: test-svc
        version: v1
      namespace: default
      clusterIPs:
      - 10.247.93.235
      ipFamilies:
      - IPv4
      ports:
        nodePort: 31354
        port: 80
        protocol: TCP
        targetPort: 80
      selector:
        app: test-svc
        version: v1
      type: LoadBalancer
    status:
      loadBalancer:
        ingress:
        - ip: *.*.*.*
        - ip: 192.168.0.15
    Table 1 Key parameters
    Type
    String
    ID of the custom EIP, which can be seen on the EIP console
    The EIP must be bindable.
  4. After the Service is updated, check the Service again.
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.custom-eip-status: '{"id":"88c197a1-cb85-4b38-b672-1d60dc5d00db","public_ip_address":"2.2.2.2"}' # After the custom EIP is configured, record the EIP and its ID.
      labels:
        app: test-svc
        version: v1
      namespace: default
      clusterIPs:
      - 10.247.93.235
      ipFamilies:
      - IPv4
      loadBalancerIP: 2.2.2.2
      ports:
        nodePort: 31354
        port: 80
        protocol: TCP
        targetPort: 80
      selector:
        app: test-svc
        version: v1
      type: LoadBalancer
    status:
      loadBalancer:
        ingress:
        - ip: 2.2.2.2
        - ip: 192.168.0.15
