Help Center/
Cloud Container Engine/
User Guide (Kuala Lumpur Region)/
Settings/
Heterogeneous Resources
Updated on 2025-07-07 GMT+08:00
GPU Settings
- GPU Virtualization: CCE uses proprietary xGPU virtualization to dynamically divide the GPU memory and compute. A single GPU can be virtualized into up to 20 virtual GPUs. Virtualization is more flexible than static allocation. You can specify the number of GPUs on the basis of stable services to improve GPU utilization. For details, see Overview.
- Default Cluster Driver: specifies the default GPU driver version used by the GPU nodes in a cluster. To use a custom driver, enter the download link of the NVIDIA driver. For details, see Obtaining the Driver Link from Public Network.
- Node Pool Configurations: If you do not want all GPU nodes in a cluster to use the same driver, CCE allows you to install a different GPU driver for each node pool. After you customize a GPU driver for a node pool, nodes in the node pool will preferentially use the custom driver. Nodes for which no driver is specified will use the cluster's default driver.
- The system installs the driver of the version specified for the node pool. The driver applies only to new nodes in the node pool.
- After the driver version is updated, it takes effect on the nodes newly added to the node pool. Existing nodes must restart to apply the changes.
- When installing the CCE AI Suite (NVIDIA GPU) add-on of v2.7.2 or later, you can configure GPU virtualization for node pools.
Parent topic: Settings
