Configuring Timeout for a LoadBalancer Ingress
LoadBalancer ingresses support the following timeout settings:
  • Idle timeout setting for client connections: maximum duration for keeping a connection when no client request is received. If no request is received during this period, the load balancer closes the connection and establishes a new one with the client when the next request arrives.
  • Timeout for waiting for a request from a client: If the client fails to send a request header to the load balancer during the timeout duration or the interval for sending body data exceeds a specified period, the load balancer will release the connection.
  • Timeout setting for waiting for a response from a backend server: If the backend server fails to respond during the timeout duration, the load balancer will stop waiting and return HTTP 504 Gateway Timeout to the client.
If you delete the timeout configuration when updating an ingress, the timeout configuration of the existing listener will be reset to the default value.
  • A CCE standard cluster is available. The table below shows which cluster versions support the timeout configuration.
    Timeout Type
    Load Balancer Type
    Supported Cluster Version
    Idle Timeout
    Dedicated
    • v1.19: v1.19.16-r30 or later
    • v1.21: v1.21.10-r10 or later
    • v1.23: v1.23.8-r10 or later
    • v1.25: v1.25.3-r10 or later
    • Other clusters of later versions
    Request Timeout
    Dedicated
    Response Timeout
    Dedicated
    Idle Timeout
    Shared
    • v1.23: v1.23.13-r0 or later
    • v1.25: v1.25.8-r0 or later
    • v1.27: v1.27.5-r0 or later
    • v1.28: v1.28.3-r0 or later
    Request Timeout
    Shared
    Response Timeout
    Shared
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Using the CCE Console to Configure Timeout
  2. In the navigation pane, choose Services & Ingresses. Click the Ingresses tab and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring timeout. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer. A load balancer can be dedicated or shared.
    Dedicated
    Listener
    • External Protocol: HTTP and HTTPS are available.
    • External Port: specifies the port of the load balancer listener.
    • Advanced Options
      • Idle Timeout (s): specifies the idle timeout of a client connection. If there are no requests reaching the load balancer during the timeout duration, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
      • Request Timeout (s): specifies the timeout duration for waiting for a client request.
        Specifically:
        If the client fails to send a request header to the load balancer during the timeout duration, the request will be interrupted.
        If the interval between two consecutive request bodies reaching the load balancer is greater than the timeout duration, the connection will be disconnected.
      • Response Timeout (s): specifies the timeout duration for waiting for a response from a backend server. After a request is forwarded to the backend server, if the backend server does not respond during the timeout duration, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
    • External Port: 80
    • Advanced Options
      • Idle Timeout (s): 60
      • Request Timeout (s): 60
      • Response Timeout (s): 60
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
    • Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
    • Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
    • Destination Service: Select an existing Service or create a Service. Any Services that do not match the search criteria will be filtered out automatically.
    • Destination Service Port: Select the access port of the destination Service.
    • Domain Name: You do not need to configure this parameter.
    • Path Matching Rule: Prefix match
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
  4. Click OK.
Using kubectl to Configure Timeout
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.id: <your_elb_id>    # In this example, an existing dedicated load balancer is used. Replace its ID with the ID of your dedicated load balancer.
        kubernetes.io/elb.class: performance
        kubernetes.io/elb.keepalive_timeout: '300'  # Timeout setting for client connections
        kubernetes.io/elb.client_timeout: '60'      # Timeout duration for waiting for a request from a client
        kubernetes.io/elb.member_timeout: '60'      # Timeout for waiting for a response from a backend server
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                      number: 80
                property:
      ingressClassName: cce
    Table 2 Key annotation parameters
    Mandatory
    Type
    No
    String
    Timeout for client connections. If there are no requests reaching the load balancer during the timeout duration, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
    The value ranges from 0 to 4000 seconds. The default value is 60.
    No
    String
    Timeout for waiting for a request from a client. There are two cases:
    • If the client fails to send a request header to the load balancer during the timeout duration, the request will be interrupted.
    • If the interval between two consecutive request bodies reaching the load balancer is greater than the timeout duration, the connection will be disconnected.
    The value ranges from 1 to 300 (in seconds). The default value is 60.
    No
    String
    Timeout for waiting for a response from a backend server. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80      10s
