Help Center/
Cloud Container Engine/
User Guide (Kuala Lumpur Region)/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Health of Worker Node Components
Updated on 2024-07-27 GMT+08:00
Check Items
Check whether the container runtime and network components on the worker nodes are healthy.
Solution
If a worker node component malfunctions, log in to the node to check the status of the component and rectify the fault.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
