Updated on 2025-07-07 GMT+08:00
Upgrade Management
Check Items
Check whether the target cluster is under upgrade management.
Solution
CCE may temporarily restrict the cluster upgrade due to the following reasons:
  • The cluster is identified as the core production cluster.
  • Other O&M tasks are either in progress or planned, such as the 3-AZ reconstruction on master nodes.
  • If the cluster contains Docker nodes but their OSs are different from that of the node pool, reset these nodes and run the pre-upgrade check again.
To resolve this issue, contact technical support based on logs displayed on the console.
