Cloud Native Log Collection
Introduction
Cloud Native Log Collection is built based on Fluent Bit and OpenTelemetry. It collects logs and Kubernetes events. This add-on supports CRD-based log collection policies. It collects and forwards standard output logs, container file logs, node logs, and Kubernetes event logs in a cluster based on configured policies. It also reports Kubernetes events to AOM for configuring event alarms. By default, all abnormal events and some normal events are reported.
In 1.3.2 and later versions, Cloud Native Log Collection reports all warning events and some normal events to AOM by default. The reported events can be used to configure alarms. If the cluster version is 1.19.16, 1.21.11, 1.23.9, 1.25.4, or later, after Cloud Native Log Collection is installed, events are reported to AOM by this add-on instead of the control plane component. After Cloud Native Log Collection is uninstalled, events will not be reported to AOM.
Notes and Constraints
This add-on is available only in clusters v1.17 or later.
Add-on Performance
Item
Remarks
Size of a log
Each individual log must not exceed 512 KB in size. In the case of multi-line logs, the length of each line will be calculated separately.
None
Maximum number of collected files
On a single node, the total number of files that can be listened by all log collection rules is limited to 4,095.
None
Log collection rate
  • If the add-on version is earlier than 1.5.0, in each cluster, no more than 10,000 single-line logs can be collected per second, and no more than 2000 multi-line logs can be collected per second.
  • If the add-on version is 1.5.0 or later, on each node, no more than 20,000 logs or 10 MB of logs can be collected per second.
Service quality cannot be ensured if any of these limits is exceeded.
Configuration update
Configuration updates take effect in 1 to 3 minutes.
None
Permissions
The fluent-bit component of the log-agent add-on reads and collects the stdout logs on each node, file logs in pods, and node logs based on the collection configuration.
The following permissions are required for running the fluent-bit component:
  • CAP_DAC_OVERRIDE: ignores the discretionary access control (DAC) restrictions on files.
  • CAP_FOWNER: ignores the restrictions that the file owner ID must match the process user ID.
  • DAC_READ_SEARCH: ignores the DAC restrictions on file reading and catalog research.
  • SYS_PTRACE: allows all processes to be traced.
Installing the Add-on
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons, locate Cloud Native Log Collection on the right, and click Install.
  2. On the Install Add-on page, configure the specifications as needed.
    • If you selected Preset, you can choose between Small or Large depending on the number of logs on nodes. The system will automatically set the number of add-on pods and resource quotas according to the preset specifications. You can see the configurations on the console.
      You can select the Small option for clusters where the logs of a single node are less than 5000/s or 5 MB/s, and select the Large option for clusters where the logs on a single node are less than 10000/s or 10 MB/s.
    • If you selected Custom, you can adjust the number of pods and resource quotas as needed. High availability is not possible with a single pod. If an error occurs on the node where the add-on instance runs, the add-on will fail.
  3. Configure deployment policies for the add-on pods.
    Scheduling policies do not take effect on add-on instances of the DaemonSet type.
    Table 1 Configurations for add-on scheduling
    Multi AZ
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
    • Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If nodes in a cluster are not in different AZs, some add-on pods cannot run properly. If a node is faulty, add-on pods on it may fail to be migrated.
  4. Click Install.
Components
Table 2 Add-on components
Component
Resource Type
fluent-bit
Lightweight log collector and forwarder deployed on each node to collect logs
DaemonSet
cop-logs
Used to generate soft links for collected files and run in the same pod as fluent-bit
DaemonSet
log-operator
Used to generate internal configuration files
Deployment
otel-collector
Used to collect logs from applications and services and report the logs to LTS
Deployment
