Before You Start
Before the upgrade, you can check whether your cluster can be upgraded and which versions are available on the CCE console. For details, see Process and Method of Upgrading a Cluster.
Precautions
Before upgrading a cluster, pay attention to the following points:
  • Perform an upgrade during off-peak hours to minimize the impact on your services.
  • Before upgrading a cluster, learn about the features and differences of each cluster version in Kubernetes Release Notes to prevent exceptions due to the use of an incompatible cluster version. For example, check whether any APIs deprecated in the target version are used in the cluster. Otherwise, calling the APIs may fail after the upgrade. For details, see Deprecated APIs.
During a cluster upgrade, pay attention to the following points that may affect your services:
  • During a cluster upgrade, do not perform any operation on the cluster. If you stop, restart, or delete nodes while upgrading the cluster, the upgrade will fail.
  • Before upgrading a cluster, ensure no high-risk operations are performed in the cluster. Otherwise, the cluster upgrade may fail or the configuration may be lost after the upgrade. Common high-risk operations include modifying cluster node configurations locally and modifying the configurations of the listeners managed by CCE on the ELB console. Instead, modify configurations on the CCE console so that the modifications can be automatically inherited during the upgrade.
  • During a cluster upgrade, the running workloads will not be interrupted, but access to the API server will be temporarily interrupted.
  • By default, application scheduling is not restricted during a cluster upgrade. During an upgrade of the following early cluster versions, the node.kubernetes.io/upgrade taint (equivalent to NoSchedule) will be added to the nodes in the cluster and removed after the cluster is upgraded:
    • All v1.15 clusters
    • All v1.17 clusters
    • v1.19 clusters with patch versions earlier than or equal to v1.19.16-r4
    • v1.21 clusters with patch versions earlier than or equal to v1.21.7-r0
    • v1.23 clusters with patch versions earlier than or equal to v1.23.5-r0
Notes and Constraints
  • If an error occurred during a cluster upgrade, the cluster can be rolled back using the backup data. If you perform other operations (for example, modifying cluster specifications) after a successful cluster upgrade, the cluster cannot be rolled back using the backup data.
  • When clusters using the tunnel network model are upgraded to v1.19.16-r4, v1.21.7-r0, v1.23.5-r0, v1.25.1-r0, or later, the SNAT rule whose destination address is the container CIDR block but the source address is not the container CIDR block will be removed. If you have configured VPC routes to directly access all pods outside the cluster, only the pods on the corresponding nodes can be directly accessed after the upgrade.
  • For more details, see Version Differences.
Version Differences
Upgrade Path
Version Difference
Self-Check
v1.23 or v1.25
Upgraded to v1.27
Docker is no longer recommended. Use containerd instead. For details, see Container Engines.
This item has been included in the pre-upgrade check.
v1.23 to v1.25
Since Kubernetes v1.25, PodSecurityPolicy has been replaced by pod Security Admission. For details, see Configuring Pod Security Admission.
  • To migrate PodSecurityPolicy capabilities to pod Security Admission, perform the following steps:
    1. Ensure that the cluster is of the latest CCE v1.23 version.
    2. Migrate PodSecurityPolicy capabilities to pod Security Admission. For details, see Configuring Pod Security Admission.
    3. After confirming that the functions are running properly after the migration, upgrade the CCE cluster to v1.25.
  • If you no longer need PodSecurityPolicy, delete PodSecurityPolicy from the cluster and upgrade the cluster to v1.25.
v1.21 or v1.19
Upgraded to v1.23
For the NGINX Ingress Controller of an earlier version (community version v0.49 or earlier, or CCE nginx-ingress version v1.x.x), the created ingresses can be managed by the NGINX Ingress Controller even if kubernetes.io/ingress.class: nginx is not set in the ingress annotations. However, for the NGINX Ingress Controller of a later version (community version v1.0.0 or later, or CCE nginx-ingress version v2.x.x), the ingresses created without specifying the Nginx type will not be managed by the NGINX Ingress Controller, and ingress rules will become invalid, which interrupts services.
This item has been included in the pre-upgrade check. You can also perform the self-check by referring to nginx-ingress.
v1.19 to v1.21
The bug of exec probe timeouts is fixed in Kubernetes 1.21. Before this bug is fixed, the exec probe does not consider the timeoutSeconds field. Instead, the probe will run indefinitely, even beyond its configured deadline. It will stop until the result is returned. If this field is not specified, the default value 1 is used. This field takes effect after the upgrade. If the probe runs over 1 second, the application health check may fail and the application may restart frequently.
Before the upgrade, check whether the timeout is properly set for the exec probe.
kube-apiserver of CCE v1.19 or later requires that the Subject Alternative Names (SANs) field be configured for the certificate of your webhook server. Otherwise, kube-apiserver fails to call the webhook server after the upgrade, and containers cannot be started properly.
Root cause: X.509 CommonName is discarded in Go v1.15. kube-apiserver of CCE v1.19 is compiled using Go v1.15. If your webhook certificate does not have SANs, kube-apiserver does not process the CommonName field of the X.509 certificate as the host name by default. As a result, the authentication fails.
Before the upgrade, check whether the SAN field is configured in the certificate of your webhook server.
  • If you do not have your own webhook server, you can skip this check.
  • If the field is not set, use the SAN field to specify the IP address and domain name supported by the certificate.
Table 1 QoS class changes before and after the upgrade
Init Container (Calculated Based on spec.initContainers)
Service Container (Calculated Based on spec.containers)
Pod (Calculated Based on spec.containers and spec.initContainers)
Impacted or Not
Guaranteed
Besteffort
Burstable
Yes
Guaranteed
Burstable
Burstable
No
Guaranteed
Guaranteed
Guaranteed
No
Besteffort
Besteffort
Besteffort
No
Besteffort
Burstable
Burstable
No
Besteffort
Guaranteed
Burstable
Yes
Burstable
Besteffort
Burstable
Yes
Burstable
Burstable
Burstable
No
Burstable
Guaranteed
Burstable
Yes
Deprecated APIs
With the evolution of Kubernetes APIs, APIs are periodically reorganized or upgraded, and certain APIs are deprecated and finally deleted. The following tables list the deprecated APIs in each Kubernetes community version. For details about more deprecated APIs, see Deprecated API Migration Guide.
When an API is deprecated, the existing resources are not affected. However, when you create or edit the resources, the API version will be intercepted.
Table 2 APIs deprecated in Kubernetes v1.29
Resource
Deprecated API Version
Substitute API Version
Change Description
FlowSchema and PriorityLevelConfiguration
flowcontrol.apiserver.k8s.io/v1beta2
(This API has been available since v1.29.)
flowcontrol.apiserver.k8s.io/v1beta3
(This API has been available since v1.26.)
  • Significant changes in flowcontrol.apiserver.k8s.io/v1:
    spec.limited.assuredConcurrencyShares of PriorityLevelConfiguration has been renamed spec.limited.nominalConcurrencyShares. The default value is 30 only when it is not specified, and the explicit value 0 does not change to 30.
  • Key changes in flowcontrol.apiserver.k8s.io/v1beta3:
Table 3 APIs deprecated in Kubernetes v1.27
Resource
Change Description
CSIStorageCapacity
storage.k8s.io/v1beta1
storage.k8s.io/v1
(This API has been available since v1.24.)
None
flowcontrol.apiserver.k8s.io/v1beta1
None
HorizontalPodAutoscaler
autoscaling/v2beta2
autoscaling/v2
(This API has been available since v1.23.)
None
Table 4 APIs deprecated in Kubernetes v1.25
Resource
Change Description
CronJob
batch/v1beta1
batch/v1
(This API has been available since v1.21.)
None
EndpointSlice
discovery.k8s.io/v1beta1
discovery.k8s.io/v1
Pay attention to the following changes:
  • In each endpoint, the topology["kubernetes.io/hostname"] field has been deprecated. Replace it with the nodeName field.
  • In each endpoint, the topology["kubernetes.io/zone"] field has been deprecated. Replace it with the zone field.
  • The topology field is replaced with deprecatedTopology and cannot be written in v1.
Event
events.k8s.io/v1beta1
events.k8s.io/v1
(This API has been available since v1.19.)
  • The type field can only be set to Normal or Warning.
  • The involvedObject field is renamed regarding.
  • The action, reason, reportingController, and reportingInstance fields are mandatory for creating a new events.k8s.io/v1 event.
  • Use eventTime instead of the deprecated firstTimestamp field (this field has been renamed deprecatedFirstTimestamp and is not allowed to appear in the new events.k8s.io/v1 event object).
  • Use series.lastObservedTime instead of the deprecated lastTimestamp field (this field has been renamed deprecatedLastTimestamp and is not allowed to appear in the new events.k8s.io/v1 event object).
  • Use series.count instead of the deprecated count field (this field has been renamed deprecatedCount and is not allowed to appear in the new events.k8s.io/v1 event object).
  • Use reportingController instead of the deprecated source.component field (this field has been renamed deprecatedSource.component and is not allowed to appear in the new events.k8s.io/v1 event object).
  • Use reportingInstance instead of the deprecated source.host field (this field has been renamed deprecatedSource.host and is not allowed to appear in the new events.k8s.io/v1 event object).
autoscaling/v2beta1
autoscaling/v2
None
PodDisruptionBudget
policy/v1beta1
policy/v1
If spec.selector is set to null ({}) in PodDisruptionBudget of policy/v1, all pods in the namespace are selected. (In policy/v1beta1, an empty spec.selector means that no pod will be selected.) If spec.selector is not specified, pod will be selected in neither API version.
PodSecurityPolicy
policy/v1beta1
None
Since v1.25, the PodSecurityPolicy resource no longer provides APIs of the policy/v1beta1 version, and the PodSecurityPolicy access controller is deleted.
Use Pod Security Admission instead.
RuntimeClass
node.k8s.io/v1beta1
node.k8s.io/v1 (This API has been available since v1.20.)
None
Table 5 APIs deprecated in Kubernetes v1.22
Resource
Change Description
MutatingWebhookConfiguration
ValidatingWebhookConfiguration
admissionregistration.k8s.io/v1beta1
(This API has been available since v1.16.)
  • The default value of webhooks[*].failurePolicy is changed from Ignore to Fail in v1.
  • The default value of webhooks[*].matchPolicy is changed from Exact to Equivalent in v1.
  • The default value of webhooks[*].timeoutSeconds is changed from 30s to 10s in v1.
  • The default value of webhooks[*].sideEffects is deleted, and this field must be specified. In v1, the value can only be None or NoneOnDryRun.
  • The default value of webhooks[*].admissionReviewVersions is deleted. In v1, this field must be specified. (AdmissionReview v1 and v1beta1 are supported.)
  • webhooks[*].name must be unique in the list of objects created through admissionregistration.k8s.io/v1.
CustomResourceDefinition
apiextensions.k8s.io/v1beta1
apiextensions/v1
  • The default value of spec.scope is no longer Namespaced. This field must be explicitly specified.
  • spec.version is deleted from v1. Use spec.versions instead.
  • spec.validation is deleted from v1. Use spec.versions[*].schema instead.
  • spec.subresources is deleted from v1. Use spec.versions[*].subresources instead.
  • spec.additionalPrinterColumns is deleted from v1. Use spec.versions[*].additionalPrinterColumns instead.
  • spec.conversion.webhookClientConfig is moved to spec.conversion.webhook.clientConfig in v1.
  • spec.conversion.conversionReviewVersions is moved to spec.conversion.webhook.conversionReviewVersions in v1.
  • spec.versions[*].schema.openAPIV3Schema becomes a mandatory field when the CustomResourceDefinition object of the v1 version is created, and its value must be a structural schema.
  • spec.preserveUnknownFields: true cannot be specified when the CustomResourceDefinition object of the v1 version is created. This configuration must be specified using x-kubernetes-preserve-unknown-fields: true in the schema definition.
  • In v1, the JSONPath field in the additionalPrinterColumns entry is renamed jsonPath (patch #66531).
APIService
apiregistration/v1beta1
apiregistration.k8s.io/v1
(This API has been available since v1.10.)
None
TokenReview
authentication.k8s.io/v1beta1
(This API has been available since v1.6.)
None
LocalSubjectAccessReview
SelfSubjectAccessReview
SubjectAccessReview
SelfSubjectRulesReview
authorization.k8s.io/v1beta1
spec.group was renamed spec.groups in v1 (patch #32709).
CertificateSigningRequest
certificates.k8s.io/v1beta1
Pay attention to the following changes in certificates.k8s.io/v1:
  • For an API client that requests a certificate:
    • spec.signerName becomes a mandatory field (see Known Kubernetes Signers). In addition, the certificates.k8s.io/v1 API cannot be used to create requests whose signer is kubernetes.io/legacy-unknown.
    • spec.usages now becomes a mandatory field, which cannot contain duplicate string values and can contain only known usage strings.
  • For an API client that needs to approve or sign a certificate:
    • status.conditions cannot contain duplicate types.
    • The status.conditions[*].status field is now mandatory.
    • The status.certificate must be PEM-encoded and can contain only the CERTIFICATE data block.
Lease
coordination.k8s.io/v1beta1
(This API has been available since v1.14.)
None
Ingress
networking.k8s.io/v1beta1
extensions/v1beta1
  • The spec.backend field is renamed spec.defaultBackend.
  • The serviceName field of the backend is renamed service.name.
  • The backend servicePort field represented by a number is renamed service.port.number.
  • The backend servicePort field represented by a string is renamed service.port.name.
  • The pathType field is mandatory for all paths to be specified. The options are Prefix, Exact, and ImplementationSpecific. To match the behavior of not defining the path type in v1beta1, use ImplementationSpecific.
IngressClass
None
ClusterRole
ClusterRoleBinding
Role
RoleBinding
rbac.authorization.k8s.io/v1beta1
(This API has been available since v1.8.)
None
PriorityClass
scheduling.k8s.io/v1beta1
None
CSIDriver
CSINode
StorageClass
VolumeAttachment
storage.k8s.io/v1
  • CSIDriver is available in storage.k8s.io/v1 since v1.19.
  • CSINode is available in storage.k8s.io/v1 since v1.17.
  • StorageClass is available in storage.k8s.io/v1 since v1.6.
  • VolumeAttachment is available in storage.k8s.io/v1 since v1.13.
Table 6 APIs deprecated in Kubernetes v1.16
Resource
Change Description
NetworkPolicy
extensions/v1beta1
None
DaemonSet
extensions/v1beta1
apps/v1beta2
apps/v1
(This API has been available since v1.9.)
  • The spec.templateGeneration field is deleted.
  • spec.selector is now a mandatory field and cannot be changed after the object is created. The label of an existing template can be used as a selector for seamless migration.
  • The default value of spec.updateStrategy.type is changed to RollingUpdate (the default value in the extensions/v1beta1 API version is OnDelete).
Deployment
extensions/v1beta1
apps/v1beta1
apps/v1beta2
apps/v1
  • The spec.rollbackTo field is deleted.
  • spec.selector is now a mandatory field and cannot be changed after the Deployment is created. The label of an existing template can be used as a selector for seamless migration.
  • The default value of spec.progressDeadlineSeconds is changed to 600 seconds (the default value in extensions/v1beta1 is unlimited).
  • The default value of spec.revisionHistoryLimit is changed to 10. (In the apps/v1beta1 API version, the default value of this field is 2. In the extensions/v1beta1 API version, all historical records are retained by default.)
  • The default values of maxSurge and maxUnavailable are changed to 25%. (In the extensions/v1beta1 API version, these fields default to 1.)
StatefulSet
apps/v1beta1
apps/v1beta2
apps/v1
  • spec.selector is now a mandatory field and cannot be changed after the StatefulSet is created. The label of an existing template can be used as a selector for seamless migration.
  • The default value of spec.updateStrategy.type is changed to RollingUpdate (the default value in the apps/v1beta1 API version is OnDelete).
ReplicaSet
extensions/v1beta1
apps/v1beta1
apps/v1beta2
apps/v1
PodSecurityPolicy
extensions/v1beta1
policy/v1beta1
PodSecurityPolicy for the policy/v1beta1 API version will be removed in v1.25.
Upgrade Backup
The following table lists how to back up cluster data.
Backup Type
Backup Object
Backup Method
Backup Duration
Rollback Duration
etcd data backup
etcd data
Automatic backup during an upgrade
1-5 minutes
2 hours
Mandatory. The data is automatically backed up during an upgrade.
CBR cloud server backup
Master node disks, including component images, configurations, logs, and etcd data
One-click backup on a web page (manually triggered)
20 minutes to 2 hours (based on the cloud backup tasks in the current region)
20 minutes
This function is gradually replaced by EVS snapshot backup.
